It is currently Mon May 18, 2026 10:16 pm
Post new topic  Reply to topic  [ 176 posts ]  Go to page Previous 18 9 10 11 12 Next
PostPosted: Sun Mar 10, 2013 9:04 am
Hey Lou - I will pick mine up at Mason Dixon most likely on Sunday. I would like to have my 87 slant D100 on the road by then but no promises.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Sun Mar 10, 2013 12:17 pm
If you don't race with us you can't have the adapter!! Hope to see you there.
Rick
PostPosted: Sun Mar 10, 2013 6:58 pm
Sounds good, Don! Long time, no see. Look forward to catching up at the drop point.
 Post subject: any one ?
PostPosted: Sat Jun 15, 2013 5:44 am
has anyone put their adapter on
is it in use
does it work in real time?
slant six's RULE!
http://www.usajon.com
 Post subject: moving ahead
PostPosted: Sun Jul 07, 2013 2:43 pm
i was planning to get my truck done this spring, but my fun budget took a few hits. i am now ready to move ahead and will post progress. going to get the trans and shifter ordered this week or next.
hoping to have it done for the clay city event.
andy. 8)
84 D100 /6 long rod 225
86 D100 /6 my sons w/offy intake/weber carb
2016 buick regal turbo
PostPosted: Sun Jul 07, 2013 4:19 pm
Hi Andy,
Thanks for the update. Mine is on hold for a while too. Glad to hear you are pushing forward!
PostPosted: Wed Jul 10, 2013 9:01 am
DynoDave
1970 Plymouth Duster
1972 Dodge Charger Rallye
1977 Chrysler Cordoba
WPC # 12304
 Post subject: update
PostPosted: Sat Jul 13, 2013 2:41 pm
ok, good news, finally got contact with lonnie diers at extreme automatics, got my quote and will be placing the order monday!! his reputation for quality is excellent and my trans is being custom built for my application, and will be partnered to a 9.5 inch converter also from extreme.
Stage 1 2004R $1495
Core $100
9.5 Converter $650
TV Correction Package $150
Shipping $150
still going to need
shifter
custom drive shaft
psi and temp gauges
cooler and lines
replace, fab, or modify cross member for mount
here is a photo of the adapter kit includes flex plate, adapter plate, crank hub adapter, hardware and instructions.
madness, i say :shock:
andy. 8)
Last edited by akbmotorsports on Sat Aug 10, 2013 1:13 pm, edited 1 time in total.
 Post subject: Header clearance...
PostPosted: Sat Jul 13, 2013 4:01 pm
If the starter is in the low mount position it might not work with those running the clifford dual long tube style headers in a car...anyone confirm a test fit to see if they are stuck with dutras or 6 into 1's or shorty's?
PostPosted: Sun Jul 14, 2013 6:54 am
A B&M Quicksilver is the only compatible ratchet shifter that I've found, depending what you're looking for.
Brooks
'72 Dart Swinger
'71 Plymouth 'Cuda
Cheap, Fast, Reliable
Pick 2!
 Post subject: you gotta laugh
PostPosted: Mon Jul 15, 2013 7:15 pm
got the trans ordered this afternoon. i am happy. wife gets home from work and says "my car smells hot". i reply "did you check the temp gauge?"
anyone wanna guess what she replied?
yup, you guessed it.
replaced blown bypass hose, bubbles emanating from coolant, head gasket at minimum. (maxda 626 12 valve/4cyl.)
the best part of the story is while on my way home from gathering parts, i saw an 80s chrysler with a riding mower stuffed in the trunk. well, some of it was in the trunk. never have a camera when i need one. right rear in trunk, left rear kinda in trunk and the rest sticking out the drivers side. hilarious.
andy 8)
 Post subject: shifter
PostPosted: Mon Jul 15, 2013 7:22 pm
i have heard good thing about these from the buick grand national crowd.
http://www.lokar.com/product-pgs/shifte ... ifter.html
thanks, andy
PostPosted: Wed Jul 17, 2013 6:24 am
Sounds like progress, Andy. I will probably duplicate your trans order. Is this the one that locks up in 2-3-4 gears, or just in 4th? Is that a 9.5" lockup converter? Thanks!
I plan to use my stock column shifter for this install, but we'll see what evolves.
DI, you can run the starter in either high or low position. There are holes/reliefs drilled for both locations on the plate.
PostPosted: Thu Jul 18, 2013 2:44 pm
hello. lockup in 3-4. bowtie overdrives is 2-3-4 and monster trans is 4 only. yes, 9.5 lockup.
there are adapters available to increase the throw on the column shift linkage, or adjustable levers for the trans shift input.
my trans is expected to be done tomorrow (fri.) now i gotta find a car for my wife since she is driving mine after the mazda blew a gasket. sending that one down the road.
glad i ordered my trans before her car broke, you know once you make the order, you can't UN order it. :D :twisted:
andy 8)
PostPosted: Fri Jul 19, 2013 5:45 am
Andy,
That sounds very promising. Lockup in 2nd sounds not so great to me anyway. 3 and 4 should be perfect.
Glad to know they can do the 9.5" lockup. I tried to get a 9.5 or 10" LU conv made for my A500 Mopar trans from a few shops, and I could not get them to do it, even though they listed that they made them. This is a major benefit to the 200-4R trans - wide converter availability.
Thanks again,
