It is currently Sat Nov 21, 2026 4:32 pm
PostPosted: Fri Jul 19, 2013 6:05 pm
Well, this sure is easier to fit-up when you actually cut the pipe square. :wink:
Now if I can only get my welds to not look like pigeon poop........
Sectioned from a 2 1/4" Dynomax mandrel 'J' bend, thought I should go bigger but that's the size I opened the manifold to. It think it should work.
Made a throttle cable bracket for the Holley using an extra mopar cable clamp and a mystery throttle/kickdown bracket from the bone pile. The generic mopar cable clamp seats nicely in the notch and around the corner of the Holley base plate so I don't have to figure out my own tab(s) to control bracket pull/rotation.
Mystery bracket gets welded to the hold down clamp then it gets chopped and tweaked.
Not pretty but works perfect. I think I'll paint it.
1966 Coronet Deluxe
PostPosted: Sun Jul 21, 2013 11:15 pm
Looks dang near perfect to me! Paint and shorten or darken that bright stud & call it DONE!
BC
