It is currently Mon Nov 23, 2026 9:10 pm
 Post subject: Crank Gear
PostPosted: Mon Jul 29, 2013 3:49 pm
How far does the crank gear need to go on? I cant find this in my manual?
PostPosted: Mon Jul 29, 2013 4:26 pm
Car Model: 1964 Valiant V200
Should go on until it bottoms against the shoulder on the crank.
Are you talking an aftermarket gear? Some of them are too tight - I had my machinist hone mine out so that it would go on all the way.
This is a rollmaster set...
 Post subject: Lol...
PostPosted: Mon Jul 29, 2013 5:16 pm
Even on the Rollmaster sets, I've never had a problem getting them to seat all the way on the crank snout after 5 minutes heating up the gear with a mapp gas torch (now taking the Rollmaster gear back off leaves a lot to be desired).
FYI, if you are using a large socket or piece of pipe and using a hammer to seat the crank gear, your #3 bearing will need to be replaced before doing any more assembly.
PostPosted: Mon Jul 29, 2013 8:17 pm
Why just number 3? And what does it do?
 Post subject: Thrust Bearing
PostPosted: Mon Jul 29, 2013 8:42 pm
That's the thrust bearing for the engine...It takes enough abuse doing it's job, hammering on an installed crank is a sure way to put the crank end play out of spec and trash this bearing.
Users browsing this forum: Amazon [Bot] and 6 guests
