It is currently Sat Jan 11, 2025 8:04 pm
 Post subject: Finding TDC
PostPosted: Sat Aug 10, 2013 6:48 pm
When using a TDC tool, I first rotated clockwise till #1 stopped, made a mark at TDC on the harmonic balancer, then rotated counter clockwise and made another mark. Is TDC on the real estate between the marks that I didn't span during the rotation, i.e. the portion of the harmonic balancer that didn't pass under the timing marks, or the real esate that did pass under the timing marks. If the former, then I must have good luck because midway between the marks is exactly on the timing mark groove on the harmonic balancer....
thanks all,
BG
PostPosted: Sat Aug 10, 2013 7:49 pm
TDC is at the center of the shorter span between the two marks.
 Post subject: shorter span
PostPosted: Sat Aug 10, 2013 9:41 pm
OK, yes, the shorter span's midpoint is exactly on the timing mark on the harmonic balancer...
bg
PostPosted: Sat Aug 10, 2013 10:31 pm
Congratulations!
Users browsing this forum: Ahrefs [Bot] and 7 guests
