It is currently Sat Nov 21, 2026 7:02 am
PostPosted: Wed Aug 14, 2013 12:59 pm
I've got a few laying around that were only used for a matter of days. Still you can see the outline of the carb bottom. Some are a rubberish material and others are paperish. I want to try a different carb as an experiment. And what is the preferable gasket for the 1945?
PostPosted: Thu Aug 15, 2013 6:27 am
lol...no luv for the newbee?
stupid question I guess
never reuse any gasket methinks
PostPosted: Thu Aug 15, 2013 6:28 am
I've reused a base gasket before when taking the carb off to clean it and such. Never after an extended period of time though. Might as well try--not a big deal if it doesn't work.
PostPosted: Thu Aug 15, 2013 6:56 am
Yea I'll reuse one for my experiment. I can't seem to get rid of an off idle glitch so I am trying another carb to see if it has any affect. Starting to think the distributor needs work, but this test may firm up that notion more.
PostPosted: Thu Aug 15, 2013 11:49 am
I coat my gasket in grease or anti seize so when you pull off the carb it doesn't ruin gasket. I do it with all sorts of cars especially vws with ported gaskets.. no probs.
PostPosted: Sun Aug 18, 2013 4:37 pm
sure. If you are scared, soak it in gas for a few minutes. then install. I reused head gaskets before with no ill effects. I was POOR back then but its hardly worth it today.
PostPosted: Sun Aug 18, 2013 4:43 pm
thanks, I used to be poor too...
has nothing to do with happiness, that I am sure of!
