It is currently Wed Jun 17, 2026 7:07 pm
PostPosted: Sun Sep 01, 2013 3:04 am
What is the best / easiest way to remove and replace the dizzy without mucking up the timing? (I have the motor out of the car and on an engine stand at the moment).
Thanks.
PostPosted: Sun Sep 01, 2013 4:29 am
take the cap off-- note the position of the rotor-- (which cylinder it is pointing at)-- remove said dizzy--- re-install with rotor pointing to same cylinder-- done.
This works if you do not change anything-- do not rotate the motor or switch to petronix--.
Lawrence
PostPosted: Sun Sep 01, 2013 6:58 am
What would switching to Pertronix do?
1964 Dart GT
PostPosted: Sun Sep 01, 2013 4:03 pm
You need to retime the engine when you install a pertronix because it's build in pickup isn't in the same spot as the points.
PostPosted: Sun Sep 01, 2013 6:54 pm
Thanks! Good to know.
1964 Dart GT
PostPosted: Mon Sep 02, 2013 3:38 am
Thanks
