It is currently Fri Nov 20, 2026 1:03 pm
 Post subject: fan blade ?
PostPosted: Mon Sep 02, 2013 3:47 pm
would like to upgrade to a more efficient fan blade..is there anything good out there?
we had a flex fiberglass on aluminum one back in the day on our 440 6pack dodge aspen and no shroud, I was bending over and moved to the drivers side revving the engine and it exploded send fiberglass into the hood..kinda dangerous
slant six's RULE!
http://www.usajon.com
 Post subject: Here are some
PostPosted: Mon Sep 02, 2013 6:07 pm
Summit.
Rock Auto.
Jegs.
Should have something. I have one of the 6-blade fans, but I forget if it's steel or hybrid.
/6 '67 Barracuda convertible, electronic ignition, 4-OD, street cam, SBP KH discs, 3.55 SG 7.25" 1" t-bars. Bilstein.
340 '67 fastback, Doug Nash 5-speed.
1988 Toyota pickup work truck
PostPosted: Mon Sep 02, 2013 10:18 pm
if you have space between the radiator and the waterpump, have you considered a mechanican fan clutch?
and also, if you have one, make sure your fan shroud is intact and the fan sits correctly in its opening. i would probably say the shroud is more important than new fan.
are you against an electric fans? or just want the simplicity of the mechanical fan?
PostPosted: Tue Sep 03, 2013 4:53 am
the car has never had a fan shroud since we have owned it.
slant six's RULE!
PostPosted: Tue Sep 03, 2013 1:32 pm
Car Model: 75valiant custom
aggressive ted did a neat upgrade to an electric fan (two, actually), which is much safer and saves fuel, too.
PostPosted: Tue Sep 03, 2013 6:13 pm
i have gone electric on mine. never looked back.
if you want a cheap and quick way to improve cooling efficiency, then go with a shroud first.
im even looking at a electric water pump conversion from davies craig http://www.daviescraig.com.au/Electric_ ... -list.aspx
but i need more green before i do this.
1964 Valiant Safari Wagon (aussie version)
PostPosted: Wed Sep 04, 2013 2:18 pm
I agree, go electric. AggressiveTed's twin fan setup can take care of most situations. I use a single electric 16" fan with curved blades now, but I am still not quite used to leaning over the engine without my heart beating harder! :shock:
BTW, I have been driving for a while without a temp activated switch for the fan, just a manual switch, and I discovered that the fan is only really needed in heavy traffic, or when idling. My engine is a stock supersix.
Olaf
Aspenized
PostPosted: Wed Sep 04, 2013 2:55 pm
Along this line has anyone tried using the temp.lite switch to turn on the fan?At what temp. does the lite come on?
81 LeBaron Salon,88 5th ave,79 Aspen SE wagon,79 W150
Don't worry, nothing is going to be alright.
PostPosted: Wed Sep 04, 2013 3:13 pm
Yes, I have.....
You can buy them that turn on at a fixed temp such as: 210, 200, 195, 185 and 175 degrees. I am running two in parallel, the first one is at 185 and the second as a safety backup at 210 in case the 185 should fail. I also have a manual override switch to turn them on anytime. When ever the fan turns on my light goes on.......
PostPosted: Wed Sep 04, 2013 4:40 pm
For simplicity I ran a Flex-a-lite (Summit FLX-1317) 17'' fan on my street driven Dart and works well.Much lighter,Aluminum with stainless blades,6 blades instead of the 4 blade factory steel.About 40 bucks new.17'' is the largest you can run with a factory radiator to clear the upper hose. I didn't have a shroud. Just a thought.
PostPosted: Thu Sep 05, 2013 5:33 pm
i have 185 deg switch in mine, and a manual switch too.
i agree that its really at low speed the fan is needed. when your moving at 30 mph or over, there fan is always off.
Users browsing this forum: DuckDuckGo [Bot] and 6 guests
