It is currently Mon Oct 12, 2026 8:00 pm
PostPosted: Wed Sep 11, 2013 1:41 pm
Well when we got my buddies scamp the car had no radiator, so I knew it had some cooling problems. Before installing a replacement radiator I dumped 4 quarts of vinigar down the thermostate housing topped off with water. 4days later I start flushing and get oarange frothy mess then it turns to a dark black sludge but nott oilly. I adventually got pretty clear water flowing. I went to remove the hoses and the outlet on the waterpump for the lower radiator hose just crumbled to pieces.
After it ran a couple hours after sitting for many years I found oil starting to seep from around the pan and front cover. I was wanting to change the pan gasket anyway and the motor mounts are just plain wasted. So I think now is the perfect time to pull the motor clean it inside and out, a fresh coat of paint and even check the timing chain.
Any idea what caused the water pump to just corroid away. My guess they ran just straight water but that would have to be for ever. Should I expect any other problems with the block or head.
PostPosted: Wed Sep 11, 2013 5:39 pm
Agreed, no antifreeze and electrolysis had it's way with the aluminum....
PostPosted: Fri Sep 13, 2013 6:27 pm
Only aluminum I have is the thermostat housing. Whatchoo talking 'bout Willis?
PostPosted: Fri Sep 13, 2013 10:58 pm
The water pumps are made from aluminum and so is the thermostat housing elbow.
PostPosted: Sat Sep 14, 2013 5:20 am
I forgot about the pump.
PostPosted: Sat Sep 14, 2013 8:09 pm
Napa sells a cast iron elbow. It requires a bit of grinding to fit nicely but it is pretty damn chunky anyway.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Sun Sep 15, 2013 3:01 pm
I bought one of those and used stainless steal allen head bolts to attach it instead of grinding it down. No more seepage from the thermostat gasket! The cast iron is stays straight and true and seals with just the FelPro gasket and without silicone gasket sealer.
PostPosted: Sun Sep 15, 2013 5:43 pm
Damn wish I had though about that. I may go ahead and replace the grades I am using now. Thanks for the idea.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Thu Sep 19, 2013 3:18 pm
I got my cast iron one from CarQuest Auto Parts. I can look for a part# if you like.
Users browsing this forum: Amazon [Bot], DuckDuckGo [Bot] and 4 guests
