It is currently Tue Oct 13, 2026 4:18 am
PostPosted: Mon Sep 23, 2013 5:00 am
I'm going to switch to a Pertronix 3ohm coil so I can bypass the ballast resister. My question is: what is the proper way to put these wires together?
This is a dual or 4 terminal resister.
PostPosted: Thu Sep 26, 2013 12:37 pm
Solder them!
Then use heat shrink over them.
PostPosted: Sat Sep 28, 2013 4:11 am
Thanks Ted, thats what I'll do.
PostPosted: Thu Oct 10, 2013 5:39 pm
im doing the same thing to my ignitor 1 should i but any fuse or anything to protect the hotcoil?
1970 Dart Swinger Matching Numbers..
PostPosted: Fri Oct 11, 2013 6:13 am
That circuit already has a fuse in it.
85 d-100 HEI 2BBl
06 Toyota Corrola
PostPosted: Sat Oct 12, 2013 11:49 am
Do not put a fuse on the coil. That will cause lots of problems with poor voltage to the coil from the fuse glowing causing a huge drop in voltage.
Also many Ignitor 1 and 11's die from low voltage and lack of cooling.
