It is currently Mon Nov 16, 2026 5:22 pm
 Post subject: what stall speed??
PostPosted: Thu Oct 17, 2013 8:49 am
alright her is what I have, 87 Dodge 150 2wd, with a 1970 super six 225 with a late 70's 904A non lock up tranny with a 9.25 posi rear with 390 gears. I am wondering what stall speed converter I should use. I work the hell out of this truck, 3000lbs on the back AND a 4500 car on the dolly, or a half of cord on the truck and 1.5 cord on the trailer. I have 2 options, 1..1700-2100 stall or 2..1900-2400
Please help'
PS I do run type F tranny fluid for a firmer shift engine is stock with 2 bbrl electronic ign with soft springs and an accel super coil with 8.8mm wires
PostPosted: Thu Oct 17, 2013 9:21 am
I just asked Rodney about this. He recommended the lower stall with that kind of load.
PostPosted: Thu Oct 17, 2013 5:22 pm
No disrespect, but why the lower. I get this thing into some sticky situations with the trailer on in the woods, backing up,steep grades,mud, etc. Just wondering why one and not the other?
Thanks
PostPosted: Thu Oct 17, 2013 8:33 pm
I would want the higher stall just for that exact reason. More grunt when trying to get a load going. 2400 isn't a lot of stall.
PostPosted: Fri Oct 18, 2013 3:34 am
Come on guys, this isn't helping much. lol I want to order this thing.
PostPosted: Fri Oct 18, 2013 4:38 am
Talk with a converter builder.
PostPosted: Fri Oct 18, 2013 7:31 am
You're talking a difference of about 300 RPM over stock with the higher stall. Order it and don't look back. :D
PostPosted: Fri Oct 18, 2013 8:01 am
Higher stall means more heat. If you use the higher stall converter with the loads you're pulling you will want a big cooler. Your highway cruise RPM should also be a couple hundred RPM above the stall speed otherwise the slipage and heat will be rather serious.
PostPosted: Fri Oct 18, 2013 11:49 am
Thanks everyone..I have made mydecision. I am going to go with the high stall. I will let you know how she pulls.
PostPosted: Fri Oct 18, 2013 7:36 pm
I think you'll be happy. In reality that is not much stall, but it will help. :D
