It is currently Sun May 24, 2026 8:42 pm
PostPosted: Wed Oct 30, 2013 1:35 pm
Car Model: 1964 Dart 270
Ok got clips off from front cover, question is does the blower motor hold the heater box up with the rubber pieces that push through the firewall?? :D
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
PostPosted: Wed Oct 30, 2013 9:45 pm
It is easier to take the whole heater box out. It is held in by three nuts around the blower motor, one screw between the rubber hoses on the firewall and a J bolt inside the vent door. Remove those and box slides out. Then you need to remove the control cables, a couple of electrical connections and the defroster tubes.
Now you can remove the box and seat it on a bench to repair. Gaskets, the heater core and various other parts are available on E-Bay for reasonable prices. While it is out you may want to install a wiper arm pivot rebuild kit and grease the wiper linkage.
PostPosted: Wed Oct 30, 2013 9:54 pm
Thanks for the info....looks intimidating at first but now it doesn't sound too bad...... :D
