It is currently Wed Aug 26, 2026 11:42 am
 Post subject: Heater core replacement
PostPosted: Thu Oct 31, 2013 6:53 pm
Car Model: 1964 Dart 270
:D
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
 Post subject: Nice...
PostPosted: Thu Oct 31, 2013 8:30 pm
Looks good, make sure to check your foam gaskets on the door next to the heater so it seals well, and I put a little bead of RTV on the mating surface of the box before putting the two halves back together so you get a better seal out of it (you may notice that the defrosters blow a little harder also after that mod).
Nice Work!
PostPosted: Thu Oct 31, 2013 8:34 pm
Thanks DI, quick question, what's the easiest way to get the clips back on the cables? Tried one tonight, didn't seem to want to clip back on very easy so I stopped to see the best way to do these without breaking anything..... :D
PostPosted: Fri Nov 01, 2013 7:15 am
Why don’t you get a heater box rebuild kit from Detroit Muscle and make it like new?
PostPosted: Fri Nov 01, 2013 2:46 pm
I'll check into that wjajr........Thanks
