It is currently Sat Aug 15, 2026 8:35 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Fri Nov 01, 2013 10:35 pm
ITs not a bad design, highly modular, ie the acc pump is seperate, the profile cams are replaceable (or manufacturable) and the spray bar can be modded, by drilling or filling holes. Idle circuit can be adapted to earlier models. I ran one on a warm Cleveland and I think I got about 5 miles per gallon. Tractor pull carbs or mudder truck. Good luck.
I didn' t buy it, I built it.....
PostPosted: Fri Nov 01, 2013 10:44 pm
5 mpg? wow. until i can find a one piece accelerator pump diaphragm for it, it will continue to sit in my shed. when i had it on my car for the couple mins that it was it seemed to run really well. it was leaking pretty bad so i didnt drive it but the rev out was impressive. i know that doesnt really mean anything but compared to the holley 390 that i had on there it was night and day. a short blip with the 390 would net 2200 rpm with the predator it would run straight out to 4k with the same throttle movement. just a quick open and closed.
PostPosted: Sat Nov 02, 2013 9:06 am
That is what makes the popular,its throttle response. I never dialed in mine in, the fan ate my radiator shortly after words, I think the throttle response actually broke a driver motor mount and the fan hit the radiator lip. For ~$100, they are still out there used.
PostPosted: Sat Nov 02, 2013 2:40 pm
its funny you say that, mine broke my timing chain.
PostPosted: Sat Nov 02, 2013 5:04 pm
I bet with a wide band you could dial that baby in tits. They were not around when I had #1, 2 or 3....Heck, hang 2-4 GM TB injectors overhead and Megasquirt it, I bet you could break another timing chain or motor mount.
PostPosted: Sat Nov 02, 2013 6:26 pm
im just gonna run the 650 and get that dialed in for now. brand new timing set and solid mounts. i dont plan on breaking anything other than my trans for a while.
