It is currently Sun May 03, 2026 7:15 pm
Post new topic  Reply to topic  [ 1333 posts ]  Go to page Previous 156 57 58 59 6089 Next
PostPosted: Fri Oct 11, 2013 12:11 pm
Car Model: 1965 Dart 270 w/ 66 Valiant front clip
Greg,
How many jet changes did it take to get that 750 right?
I thought about using one...
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
PostPosted: Fri Oct 11, 2013 2:08 pm
Online
Greg,
The 750 Carter was pretty Close - Either stock Jetting or one change..
The 750 Holley I coult not get to run right. I think it's too Big for the engine or I have not fiddled with it enough yet.
 Post subject: Carnage 10/13/13
PostPosted: Sun Oct 13, 2013 8:06 am
Online
Well it was bound to happen..
The ole Stock type oil pump drive gear and Cam gear interface have failed.
Fortunately I lost oil pressure while idling in the line for tech.. So no massive rod or crank damage... New bearings and a crank polish and the bottom end of my engine is in business.
While I have the ruster engine apart I will do some fiddling... Mainly lightning / knife edging / smoothing the crank.. adding compression and going to 1.6 roller rockers.
Also I will add the Engine plate, And go to a crank trigger system along with a vacuum pump and an external oil pump.
Here are some pics of the Disaster:
Pistons / rings / cylinders looked great!
Rods were good. One bearing was shot:
Heres the UGLY...
This was a Doc's hardned gear... I Got 3 years of hard racing out of it!
Cam Carnage:
PostPosted: Sun Oct 13, 2013 11:51 am
Greg,
Did your oil pump have the extra tube to spray oil right onto the gears? At least going to the external pump will allow you to reuse the cam if you want. I am glad that it didn't tear things up really bad.
Rick
PostPosted: Sun Oct 13, 2013 1:34 pm
Greg, glad it was not any worse! You have had a challenging year, but you have kept a positive outlook! I look forward to seeing Ruster at the track next year going even faster!!
Brian
Flyin' Brian
"Sixy Beast"
PostPosted: Sun Oct 13, 2013 4:31 pm
ever since I have used doug`s positive oiling tips on the cam/oil drive gears I have no problems up to 6800rpm. also with a polish of the gear teeth to take the sharp edges of before running it. the drilled pump from the pressure side is the best compared to the tube feed line.
PostPosted: Sun Oct 13, 2013 4:53 pm
Online
Greg,
Rick
No I did not do that mod.
I was too anixous when I did the build the first time. I probably should have done the oiling gear mod.
It was time to pull the engine apart anyway... this was a good excuse to do so.
PostPosted: Mon Oct 14, 2013 6:21 am
That's it,,Positive out look !
 Post subject: 11-4-13
PostPosted: Mon Nov 04, 2013 7:59 pm
Online
Well I have Taken the Crank to the machine shop for Checking / Polishing / Lightening / knife edging. I did Not weigh the Crank this Time before sending it to the Shop, So I will have to check this thread and my notes to see the Before weight.
I also have Begun to lighten and cut stuff again.
I have plans to Tie the front frame rails in with 4130 Tubes so I will be able to Get rid of most if not all of the sheet metal up there from Ma Mopar. Here are some before shots with the front Clip off.
I have yet to weigh any of the junk that I have taken off yet, but it's a Pound or 2 .. Lots of gunk scraped from the k Frame.. and I got rid of the Trunk Gasket and other odds and ends..
I plan to Lighten the front clip as much as possible.
Here is some work on the wheel tubs.... The New Tubs will be Light Aluminum :-D- I need to do this to run the New Wheels I bought in the Summer.
I also Decided to attempt to Get rid of the factory package tray and Go with all aluminum sheet. Should be lighter!
PostPosted: Mon Nov 04, 2013 10:32 pm
Lovin' it, Greg! You will have the lightest 2nd gen A-body on the planet soon...
I only reuse stock used pumps and regrind cams now, and no problems yet. Tilley told me the same thing recently, that he had switched to that mode.
PostPosted: Tue Nov 05, 2013 7:13 am
Greg;
I remember a MoPar guy that hole-saw his K-frame and, put a rack/pinion steering on it...
Do they make a chromoly tubular K-frame???
Destroked 300 (272ci)
PostPosted: Tue Nov 05, 2013 8:34 am
Check out QA1 for 67 up tube K frames
PostPosted: Tue Nov 05, 2013 8:42 am
Online
Thanks Romeo! already Know about it.
But thanks for throwin it up here.
I have not seen a price or weight on them yet :-(
I can also Modify a stock one with some 4130 Tube too:-)
PostPosted: Tue Nov 05, 2013 8:44 am
Online
Greg;
Yep I might Grind a Bunch out of it this winter.
Not yet sure on the rack / Pinion Setup.
PostPosted: Tue Nov 05, 2013 9:43 am
Greg, unless you really, really need a lot of room for oil pan/headers I would stay away from rack and pinion. It opens up a whole can of worms for front end geometry, and most of it is bad.
Yes, you can cut a ton of weight out of a stock K-frame, and it will bolt in when you're done.
Users browsing this forum: Greg Ondayko and 1 guest
