It is currently Fri May 01, 2026 10:05 pm
Post new topic  Reply to topic  [ 1333 posts ]  Go to page Previous 157 58 59 60 6189 Next
PostPosted: Tue Nov 05, 2013 3:11 pm
I just thru it out there for Six Gun. Ahha to be young again !Maybe that is why my mid section is growing.
PostPosted: Tue Nov 05, 2013 5:45 pm
This looks like something you can do...
http://i241.photobucket.com/albums/ff92 ... ember5.jpg
Destroked 300 (272ci)
PostPosted: Wed Nov 06, 2013 4:58 am
YES,
YES I CAN! and Probably Lighter and Better than that one !
Just Practiced some tiggin on old scraps of 4130, No problems there! That Welding class I took last spring was the best $400 I have spent yet!
PostPosted: Wed Nov 06, 2013 7:27 am
That looks like a Bob's Profab K-frame job. He cuts out a lot of weight. :D
PostPosted: Sun Nov 10, 2013 10:10 am
Well Here are some more shots of the Wheel Tub progress:
At Last check in this post:
http://www.slantsix.org/forum/viewtopic ... &start=825
I state that Ruster's Calculated weight was: 2158.7#
After Taking cutting some stuff off for the RR Wheel Tub Install I deleted 22.9# from the car, But I added 3.3# for the Sheet Alminum Wheel Tub on the Right Side.
So now Ruster Should be at 2139.1# - Inching Ever closer to 2100# Without Driver.
Here are some Pics:
Some More Trimming Before Installing the Wheel Tub:
This kit Gets Rid of the Rear Dogleg :-0
Here is the Summit racing Wheel tub kit - Quite a Bit of room in here, Lots of trimming to fit my application.
Here is all of the Steel Removed to make room for the tubs... -22.9#
And here is 3.3# of aluminum Tub to replace it.
PostPosted: Sun Nov 10, 2013 5:34 pm
Car Model: 1967 Dodge Dart 270
Man you really need to get a old slingshot dragster frame and call it good. I can even come over and help you work on it. :D
PostPosted: Sun Nov 10, 2013 8:53 pm
This is much more fun to watch...
 Post subject: 11-11-13 More Losing
PostPosted: Mon Nov 11, 2013 6:29 am
I finished up the Right Rear Tub, and i decided to take a bit more weight off of the Right Side..
The front passenger door is a perfect place to begin.
I was able to get 2# out of the door.
Calculated weight is:
2139.1#
- 2 #
2137.1#
and I also Had a bit of fun modifying the Exterior Door Handle... Did not loose any measurable amount of weight there :-(
Pics:
Stuff Not needed on the passenger door:
2 Pounds Lost:
Passenger Door handle Before:
Passenger doorhandle After:
Now onto the Driver's Side Wheel Tub.
PostPosted: Mon Nov 11, 2013 7:30 am
My thoughts are the same as Brian, Just get a old F.E.D. and call it a day.
PostPosted: Mon Nov 11, 2013 4:48 pm
Greg;
keep cutting on that car, anyone can make a dragster go...
PostPosted: Mon Nov 11, 2013 7:22 pm
Here are some shots of the RR Completed Wheel Tub:
And I started to cut out the Left Side Wheel Opening:
here is all the Old metal that came out of that side:
It deleted 14.9# off the car:
So Ruster was at 2137.1# This morning
- 14.9# for the LR Wheelhouse,
Now Ruster is at
2122.2#
PostPosted: Tue Nov 12, 2013 4:21 am
You are getting into Seymour territory there. You just need to trade (human) bodies with him and you'll be there... :roll:
PostPosted: Tue Nov 12, 2013 7:09 am
I dont think it will be the lightest 2nd gen a body ever..
It might be quite a bit heavier thanthe wire car:
http://www.allpar.com/racing/missile/wire-car.html
1800# without Driver..
Who knows... Maybe someday..
PostPosted: Tue Nov 12, 2013 4:58 pm
That's what I need, a Titanium/Magnesium rear-end!!!
http://www.allpar.com/photos/racing/wir ... m-rear.jpg
PostPosted: Tue Nov 12, 2013 9:05 pm
Greg,
I had asked about the 750 you are running before and you mentioned it was fairly close to stock. I have the Edelbrock 750 which I believe is the same as the AFB Competition. Stock jetting is at 113/107. Think this is to much?? Or should I play around with metering rods??
The engine should be close (hopefully) to 12:1 compression. I keep hearing it will be too much, but I have seen quite a few /6's with 750 carbs.
I'm sure something else may work better but I'm not wealthy enough to play with all the options out there. Using what's laying :lol:
Good job on the weight reduction! If I ever get the tube chassis car done, I am really not sure it will weigh much less than where you are now. I'm starting to question whether it's even worth it. I think I should just go for the stock bodied car build. It is less expensive to do what you are doing and a lot less headache.
Thanks for the inspirational thread.
Michael Glass. Mopar stuff and some rusty Mopar stuff!
1965 Dodge Dart with 66 Valiant front clip. Other stuff...
