It is currently Fri Nov 13, 2026 11:49 pm
Post new topic  Reply to topic  [ 35 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Fri Nov 15, 2013 5:56 pm
slantsteve, it is centered well, when i test fit the adapter on the engine i measured the center hole of the plate to the crank and it is perfectly centered. i then test fit adapter on the trans and measured to the input shaft of trans and again was centered. should be good.
andy 8)
84 D100 /6 long rod 225
86 D100 /6 my sons w/offy intake/weber carb
2016 buick regal turbo
 Post subject: opinions please
PostPosted: Fri Nov 15, 2013 6:14 pm
hello. here is the mount i made. should i keep it or scrap it?
view from side
and from rear
the rear of the engine (measured off the rear oil pan rail) is about 1/8 inch lower than measured before removing old trans. how much tolerance is acceptable as far as drive line angle is concerned?
i plan to put struts off the cross member to the upper frame.
andy. 8)
 Post subject: Lookin' good...
PostPosted: Fri Nov 15, 2013 6:49 pm
Typically no more than 5 degrees is best (less is better, but they put a little fudge in there as the rear axle bounces up and down...those guys that jack the truck up remount the rear axle tilted to make up for the angle).
That mount should work great for the application (and would be stout enough for a warmed over small block as well).
PostPosted: Fri Nov 15, 2013 7:05 pm
thanks, the price was right :D used pieces from scrap metal pile.
andy 8)
PostPosted: Fri Nov 15, 2013 7:52 pm
You want the pinion angle to be the same as the out put shaft angle. They do not have to line up, but should be the same amount off level. You can use tapered shims to correct the pinion later if needed. Your craftsmanship looks quite nice.
Sam
 Post subject: progress
PostPosted: Mon Dec 02, 2013 1:33 pm
hello all. thanks for the replies. got the eng/trans and pinion both at 4 degrees. got the sonnax throttle corrector, lokar flexible dipstick, throttle and TV cable installed, haven't adjusted TV yet.
getting the drive shaft ordered later this week from dennys. they are giving $50 bucks off thru the rest of the week.
lokar bracket and cables.
right side of 200-4r dipstick (rear-left in pic) and tv cable
getting closer :D
have a great day, andy.
 Post subject: parts list
PostPosted: Mon Dec 02, 2013 1:56 pm
here is a list of what i have used so far, will add as progress continues.
Lokar DP1000HT60 throttle cable (60 inches), bracket and return springs
http://www.jegs.com/i/Lokar/625/DP-1000HT60/10002/-1
Lokar KD2200RHT60 kickdown (TV) cable kit
http://www.summitracing.com/parts/lok-kd-2200rht
Lokar TD3200RFM dipstick
http://www.jegs.com/i/Lokar/625/TD-3200 ... tId=749848
Lokar ACA-1802 adjustable shift lever
http://www.jegs.com/i/Lokar/625/ACA-1802/10002/-1
Sonnax AS5-05K edelbrock throttle corrector kit
http://www.sonnax.com/parts/2767
Energy Suspension 3-1108-G mount
http://www.jegs.com/i/Energy+Suspension ... G/10002/-1
trans jack from homedepot.com $159 + tax, free shipping
http://www.homedepot.com/p/Big-Red-1-00 ... qEsyCembqJ
Denny's Driveshaft
http://www.dennysdriveshaft.com/p1291_1 ... shaft.html
andy.
Last edited by akbmotorsports on Thu Dec 05, 2013 5:52 pm, edited 3 times in total.
PostPosted: Mon Dec 02, 2013 4:08 pm
Andy,
This all looks like very nice work, and you are saving us all trouble by posting this. I wish I were as disciplined about posting these things.
 Post subject: .
PostPosted: Wed Dec 04, 2013 10:21 pm
I hate to sound like a wet blanket, but the driveshaft/trans angle set at 4 degrees is going to vibrate like hell. The front joint should be set to about 1/2 degree, and the rear set to 2-3 for a dailey driver. The idea is to compensate for drive axle wrap-up, and have the u-joints perfectly strait at WOT. Full blown, track only drag cars can use as much as 4-8 degrees at the rear joint.
 Post subject: angles
PostPosted: Thu Dec 05, 2013 5:28 pm
BS6F, the 4 degrees aren't the u joint angles, it is the degrees at which the pinion shaft and trans shaft are set, if i read your post correctly. i will check those when the new drive shaft arrives and is installed. i see your point about the pinion angle changing under acceleration though. i guess i can adjust if needed.
i plan to install some sort of device (super-springs, caltech, trac bars...) and new leafs next year to reduce axle wrap.
great input from all. i love the things i learn along the way on this stuff. even though i have probably read most of it here already, it doesn't always "stick" until i work through a project.
thanks, andy. 8)
 Post subject: update
PostPosted: Mon Jan 20, 2014 6:34 pm
greetings from the winter wonderland. tired of hibernating. hope all had a good holiday.
finally got the drive shaft delivered last week.
relative to the shop floor, both trans and pinion shaft are 4 degrees, and installed the shaft tube is 6 degrees, 2 degree u joint angles.
using a quality piece of 5/16-24 threaded rod and rod ends, got the column shifter connected. i used the bracket from the 727 with the plastic bushing, straightened it, GENTLY removed the welded stud, rebent it to be 3/4 inch shorter, redrilled the holw where the stud was to 7/16 and used the adapter plate bottom bolt hole as a mount pad.
the bad news is with the added spring tension of the throttle valve, the long throttle cable was struggling to pull the last 5-10% of throttle travel. it has been removed and i am putting the set up i had before, leaving the Lokar bracket in place for the TV cable.
it hasn't bothered me too bad to have the truck indoors during all the snow and cold, but can't wait to drive it. getting closer. :D
andy.
 Post subject: fiil 'er up
PostPosted: Fri Feb 21, 2014 5:44 pm
tomorrow is the day this experiment will yield some results, hopefully positive ones. everything is installed, triple checked and ready for filling, pressure check and then, as long as the psi checks good, drive.
extreme automatics 200-4r install instructions;
http://www.extremeautomatics.com/assets ... nstall.pdf
repaired the speedo cable as the 200-4r has the same thread on the speedo drive. now if my gauge works? installed a VDO electric trans psi gauge.
will be using dexron 6 fluid.
andy 8)
PostPosted: Mon Feb 24, 2014 5:09 pm
hello. i put about 30 miles on the new trans and went well. very smooth operation of trans and driveline. all systems go, almost.
they mistakenly forgot to install a pressure switch for lockup in 3rd but will be easy to remedy requiring dropping the pan and installing switch and connecting a wire to existing 4th pressure switch.
converter stall is too high for my needs, lonnie (extreme automatics) is going to lower the stall on my existing converter.
O/D with lockup is awesome, 60 mph at about 1500 rpm. longer drives will be a pleasure.
thumbs up for extreme automatics, lonnie and i had email conversation until about 10 pm saturday and sunday nights.
andy 8)
PostPosted: Mon Feb 24, 2014 5:27 pm
What is the stall? That would probably be perfect for Lou!! :lol:
Rick
PostPosted: Tue Feb 25, 2014 2:58 am
Yeah, what Rick said! What stall now (standing still, brakes hard applied, max throttle before breaks tires loose, read tach)??
Anyway, sounds like Lonnie is the guy to go with. I should get moving on this...
