It is currently Wed Oct 14, 2026 3:19 pm
 Post subject: Slant 6 Runs and dies!!
PostPosted: Sat Nov 16, 2013 5:20 pm
Great info!!! I don't think that this engine is original, probably a late 70's! I couldn't find any numbers on the block by the #6 cyl. but I'll try and find out what year motor is!! It ran fine and started missing bad so they rebuilt the carb and that was the beginning of the nightmare!! I will read up and dive back into her next week!! Thanks for all the help!!
PostPosted: Sun Nov 17, 2013 10:07 pm
How does it die? When you let off the key? After idling? After putting load on it?
1970 Plymouth Duster, 198 Slant Six, Super Six setup w/ EI conversion
http://www.semisynthetic.net/kill-9/gal ... p?album=34
PostPosted: Sun Nov 17, 2013 10:25 pm
This thread started here: http://www.slantsix.org/forum/viewtopic.php?t=53873
 Post subject: Slant 6 runs and dies!!
PostPosted: Mon Nov 18, 2013 6:27 am
I'm having trouble replying!! What do I do to reply? It runs a little while when I let off the key to the run position!! It sounds like it floods out! I pump the gas and it tries to run but eventually dies. Runs rough but sometimes it sounds like it is hitting on all 6!! I don't know how to post photos or I could give you a few pictures!! Sorry about reply troubles!! Thanks so far!!
PostPosted: Mon Nov 18, 2013 9:54 am
Have you checked the condition and gap of the points in the distributor?
PostPosted: Mon Nov 18, 2013 10:43 am
Fixin' to jump on it in a bit!! Started her up this morn and she started right up and was hitting on all six and then it seemed like it was starving for gas! I pumped the pedal but she just died!! I can't figure out if it's flooding are starving!! Oh well, thanks for the info!! I'll make sure she's timed right and check the points and take it from there!!
 Post subject: flooding?
PostPosted: Mon Nov 18, 2013 3:28 pm
next time after car starts , and engine dies, remove a spark plug and
look if it is covered in gas.
I had a similar problem where it would not start, after removing a plug
found it was covered in gas. I changed carb and now it is okay.
PostPosted: Thu Dec 05, 2013 12:18 pm
Hey y'all, got her running like a champ!! P O changed the coil and got the wires switched around!! Swapped 'em and started right up and purrs like a kitten!! Thanks for the help!!
Users browsing this forum: Amazon [Bot], Bing [Bot] and 11 guests
