It is currently Mon Jun 15, 2026 4:10 am
 Post subject: 5 volts
PostPosted: Sat Nov 16, 2013 4:38 pm
I'm installing a Devils Own Alcohol/water injection kit. It utilizes a GM MAF/map sensor. This sensor needs 5 volts. How can I get 5 volts?
Thanks,
B
These ones go to eleven...
PostPosted: Sat Nov 16, 2013 5:03 pm
Google 5v voltage regulator and it will give you schematics. This was brought up a week or so ago when I talked of using a map to judge if a cold air scoop would help on VE. It's about 3-4 cheap radio shack pcs and easy to solder. Let us know how it works out.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
PostPosted: Sat Nov 16, 2013 5:29 pm
Thanks, Ssg.
I looked at the schematics, boy.. I will make the circuit board as a last resort.
But it will look terrible, my engine compartment wiring already looks like a telephone switch board from the 1950's put together by monkeys.
I was hoping for some sort of module.
If I do make this thing, are there housings and or ways to make it look clean and protect it from the hazards of my engine bay?
Sounds like it might be a trip to Fries tomorrow.
BT
PostPosted: Sat Nov 16, 2013 10:25 pm
Car Model: 1966 2D Dart
To get 5 volts for sensor I would use USB mobile phone / iPad charger as a donor for the regulator electronics. The board inside is less than half od square inch and easy to capsule with scrincable insulation tube etc.
PostPosted: Sat Nov 16, 2013 10:54 pm
good idea.
Instead of taking it apart to get to the board, just cut off one end of the USB cable to get to the power wires.
PostPosted: Sun Nov 17, 2013 4:54 am
The USB thing isn't a bad idea either.
If you needed protection in the engine bay, radio shack sell small "project boxes" that can be sealed.
No need for a bread board, it's 4 pcs total if built. It like the USB would take up very little room. You may have a phone charger laying around which would be quicker.
PostPosted: Sun Nov 17, 2013 8:46 am
Thanks for the options, I will look for an old car charger and If not it sounds like a trip to Radio Shack.
Cheers,
B
PostPosted: Fri Nov 22, 2013 8:25 am
Car Model: 75valiant custom
http://www.slantsix.org/forum/viewtopic ... nt+cluster
and especially,
http://www.allpar.com/history/mopar/electrical2.html
i don't know if this will help you, but it sure helped me. and it was EASY and CHEAP.
PostPosted: Fri Nov 22, 2013 11:46 pm
Thanks, good info.
I installed the converter today and it works. And the car started for the first time since I installed the turbo!
Cheers.
PostPosted: Fri Nov 29, 2013 5:31 am
Congratulations! Keep us appraised of progress. The amazing value of this forum once more demonstrated.
Sam
