It is currently Mon Nov 30, 2026 12:35 am
PostPosted: Tue Dec 17, 2013 8:30 am
:? my 75 dodge van with a 225 slant 6 -3 speed 250 or 230 tranny...,going in for complete tear down.....bodywork,paint,the works, need advice from the pro's on engine ..full rebuild or not...motor is going to tore down and redone...should i go the with the full rebuild kit,...pistons ,cam shaft,timing chain, rings, ect....or should i only need to change certain parts...motor sound good but ...theres is some tapping,but no knocks,...if so where can i find mopar rebuild kits that are specific to this dodge motor .....im am not a mechanic and only have a basic understanding of the process... so while being in paint shop my mechinic is going to do all this work.rebuild motor and tranny 1600.00 + parts....so i really really need some real pro (printable )..advice and a recipe on how to proceed without costing me fortune.....thanks john in pa
new owner of a 1975 dodge street van seeking wisdom from other slant 6 owners
PostPosted: Tue Dec 17, 2013 8:44 am
You are going to want to tell us if youre going for mild or wild. Your driving type and other details. Most likely you'll want low end torque so do a search for a bit and read up. I know aggressive ted has a torquer build and dadtruck done a lot of research on his which is told to be a stump puller.
225, Offenhauser, Holley 350, A833OD, 3:55, GM HEI,99 Durango starter
BOOSTED! WH1C, BIG FMIC, 10#
Operation Noble Eagle 03-05
Operation Iraqi Freedom 05-07
Operation Enduring Freedom 12- 13
PostPosted: Tue Dec 17, 2013 9:12 am
mild...basic driver ,city ...not speed way...,base model van as base as u can get in 1975, cheapest way to go with best long lasting results (long lasting effects ) looking for longevity ...thanks i think
PostPosted: Tue Dec 17, 2013 9:25 am
Backing way, way up...
What are your transportation needs? Why do you want to meet that need with a 40 year old van?
