It is currently Sat Jun 20, 2026 10:49 pm
PostPosted: Wed Dec 25, 2013 12:11 pm
Trying to finish my driveline off. Engine is a 225, professionally ported/polished head with enginebuilder valves, clifford intake manifold, holley 650dp blowthrough. Haven't decided on the turbo setup yet. Transmission is a 904 with manual valvebody, race bands/seals/clutches.
Rear end is a 8 3/4 with a spool and 2.76 gear. What should I use for a torque converter? Would the stock one be good?
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
PostPosted: Wed Dec 25, 2013 1:13 pm
The stock torque converter is not a heavy duty piece and should be upgraded. When I was talking to a converter builder about forced induction we agreed that a tight 10" converter would be best as too much slippage at the moderate engine speeds of a 225 will cost in terms of ET and MPH. You are going to have a tough time with 2.76 gears if you're still planning on drifting. Only light, fast, turbo A bodies have been able to make good use of 2.76 gears at the track. Drifting happens at lower speeds and you need to gear appropriately. 4.10 is probably not too much.
PostPosted: Wed Dec 25, 2013 3:21 pm
Cam . compression, converter and gears......
It all needs to be a compatible combination.
Josh is right....heavy car .....low speeds....big verter and low gears.
With a 750 DP it will fall flat on its face if you cant get the revs up.
Id be at 3500 stall and 4.56 gears with 26" tires.
PostPosted: Mon Dec 30, 2013 2:03 pm
This is for a drag car. Car is looking to weigh in around 2750 when done. Stock cam, 8.4:1 comp ratio, 2.76 gears, 26 inch tall tire. Head is ported/polished with enginebuilder valves. Other than that it's stock.
2002 Subaru OBS
PostPosted: Mon Dec 30, 2013 4:06 pm
You're not going to be able to go fast enough to take advantage of 2.76 gears. Then again with a stock cam and bottom end it might not spin fast enough to take advantage of numerically higher gears. Time for cut-and-try! :D
PostPosted: Tue Dec 31, 2013 1:40 pm
This is a turbo car.... Blow thru 650 & turbo mentioned by OP.
11.02 @ 120.56
Chassis dyno
PostPosted: Tue Dec 31, 2013 2:08 pm
Yep. And it still needs a better converter and cam to go fast. You lived this so you can let him know what he needs to make the plan work.
PostPosted: Tue Dec 31, 2013 2:17 pm
Tom and I spoke this morning and sorted everything out. Thank you for you help as well Josh.
-Ryan
2002 Subaru OBS
