It is currently Fri May 15, 2026 6:36 pm
PostPosted: Mon Jan 06, 2014 4:50 pm
Car Model: 1964 Valiant V200
While swapping parts on my '64 Valiant I discovered that one of the steering box mounting bolts is torn out of the K-member. It's the one nearest the motor so I don't think I can just weld a 7/16 NF nut on the back of it. Must be all those miles of driving on LA roads and a few years of hard driving in vintage rallies. Also explains the vagueness I sometimes felt.
I haven't got the motor out but I think this means that I need to pull the K out of the chassis, which was not something I was planning on.
Any repair advice?
PostPosted: Mon Jan 06, 2014 8:21 pm
Can we get pics please? I'm a visual person. Thanks :)
Leela: 1970 Dart 225 CID
Coulmn Shift TorqueFlite
7 1/4" Axle 2.76 Gears
Go ahead and save that weird car, the sedan, the 6 cylinder, the C-Body. If you want a big block musclecar and that's all you care about, your missing the point.
PostPosted: Mon Jan 06, 2014 8:29 pm
is this on a slant car? or a v8 car?
if its a slant car there might be enough room to drop the exhaust and pull the strewing box..
then get a heli coil thread repair kit in the thread size you need.
hopefully there will be enough room to get a drill and tap in there.. also maybe a right angle drill head could help too.
good luck.
PostPosted: Tue Jan 07, 2014 1:35 pm
Slant - and luckily the engine is coming out soon-ish. So I should have lots of room. I'm just not sure that a helicoil will work.
