It is currently Tue May 26, 2026 5:40 am
 Post subject: 68 D200 compatability
PostPosted: Mon Jan 13, 2014 8:19 am
Hello, I've done a fair amount of searching and it seems that anything 68 and on works. Specifically I'm thinking about replacing my D200 225 (3 speed man tran) with an 80"s variety Slant with hydraulic lifters. I think the answer is it'll work. But I'm looking for some confirmation. Thanks for any input.
68 D200
PostPosted: Mon Jan 13, 2014 10:19 am
You should be fine so long as the flywheel and crankshaft have the large pilot diameter. You will need to sway oil pans and pickup tubes.
PostPosted: Mon Jan 13, 2014 10:40 am
Thanks for the quick answer.
68 D200
 Post subject: How do you know
PostPosted: Tue Jan 14, 2014 8:12 am
How do you know if it has the large pilot diameter??
68 D200
PostPosted: Tue Jan 14, 2014 9:01 am
The change happened for the 1968 model year so you should be fine unless your original engine was a leftover from '67. The only way to know for certain is to pull the clutch and measure the flywheel center hole. The measurement can be found in the articles section.
PostPosted: Tue Jan 14, 2014 11:26 am
Thanks Josh. I really appreciate it.
68 D200
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 7 guests
