It is currently Sun Nov 22, 2026 8:34 pm
 Post subject: Fuel Pump Vent Hole
PostPosted: Tue Feb 04, 2014 5:38 am
Hello, Is it possible to block off the vent hole on a stock style lever arm Fuel pump?
Mine squirts out all kinds of oil(out of the Vent hole) and I will be putting a vacuum pump on the engine this time around anyway. So I am attempting to seal up all leaks.
This would be on the Ruster Race engine.
Just curious about it.
I dont really want to go to an electric pump if I can avoid it.
PostPosted: Tue Feb 04, 2014 6:34 am
replace pump ...should not be leaking anything out vent
PostPosted: Tue Feb 04, 2014 9:03 am
I think this is more due to the Oil scrapper and windage tray that I have on that side of the engine.. The Fuel pump itself works fine. I wonder if the scrapper is sending an abnormal amount of oil near the pump arm?
Remember this is on a 6500+ rpm race engine, Not on a Street motor.
I guess I can try another pump and see what I come up with.
it still does not solve the Vacuum Pump / Seal issue.
PostPosted: Tue Feb 04, 2014 9:53 am
I add a fitting so I can vent to a higher location or into a "pressure source". (Turbo boost)
PostPosted: Tue Feb 04, 2014 10:29 am
Excellent, I think that what I was looking to do anyway.. Can I tie it into the Valve cover or some other area that the vacuum pump will be pulling a vacuum on?
PostPosted: Tue Feb 04, 2014 10:49 am
You do not want a lot suction on the back-side of the diaphram because the pump will not "pump" fuel.
Another option is to make a special fuel pump gasket to block oil access into the pump housing, as much as possible.
PostPosted: Tue Feb 04, 2014 12:41 pm
Again Excellent Considerations.
Thanks Doc.
