It is currently Mon Sep 28, 2026 7:55 pm
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Mon Feb 24, 2014 3:49 am
Brodie,
I would recommend O-ringing the block, too, to prevent (hopefully) head gasket failures. It's a lot of work, but will give you some peace of mind, and maybe prevent headaches, down the road.
Bill, in Conway, Arkansas
Just something to consider. When I first did my turbo (1979), I had tuning problems. Went into detonation a lot. Would blow head gasket.
So instead of correcting the detonation problem (cause) , I "O" ringed the block and used a copper head gasket (symptom). Cured the head gasket problem, and started eating pistons. I would have been better off not "O" ringing the block, and letting the stock head gasket act as a "fuse" (blow the gasket instead of pistons), untill I got the tuning right. At 10 PSI, I don't feel "O" rings are required (if the tune is right).
 Post subject: Low boost...
PostPosted: Mon Feb 24, 2014 8:59 am
Charlie.
Thanks a lot for the tutorial! Like I said, I am just a newbie at this and am in no way, qualified to give advice. I was thinking about the possibility of him running 15 pounds of boost, down the road, which he had said he might try,
I agree, 10 pounds is not really enough boost to require O-Rings, if that's all he runs.
Thanks again!!!
Bill
1964 Valiant 4-door sedan, 225 turbo/904
PostPosted: Mon Feb 24, 2014 10:22 am
I can always try out 10psi and see how I like it. If I think I would wanna go to 15psi, I could always run the 10psi in the motor and build the engine that the turbo engine replaced.
-Brodie
1977 Dodge D100 stepside, slant six/3 on the tree
2002 Chrysler 300M Special (daily driver)
PostPosted: Mon Feb 24, 2014 10:33 am
Boost is like drugs...once you have a taste you want more. There is no going back once you try 15 psi.
11.02 @ 120.56
Chassis dyno
PostPosted: Mon Feb 24, 2014 12:21 pm
Take it from one who's been there... LOL!!! :)
PostPosted: Tue Feb 25, 2014 3:45 am
I agree. All power adders are addictive. Turo or nitrous.
And tuning is much easier now, then when I did mine. In '79 it was hard to get any turbo info. No such thing as electronic timing control. No wide bad O2 sensor. All I had was an EGT gauge from an airplane, and my ear. Was about impossible to hear detonation, at WOT.
I did have water/alcohol injection. A windshield washer pump, and nozzles that turned on with a pressure switch at 5 psi and sprayed right down the carb barrels. (draw thru system)
