It is currently Sat Nov 21, 2026 8:59 am
 Post subject: 1965 904
PostPosted: Wed Apr 09, 2014 4:02 pm
Planning on rebuilding my 904 in 65 valiant with slant six.
I was told or read somewhere this is a one year only transmission? What makes it so, if true. And also whats my best bet for a complete parts kit. I have a manual already.
Trans has always been kinda slippy, but after I parked it for some carb problems. Trans is pouring fluid. Its on level ground, either from the rear of the pan, or above it.
PostPosted: Wed Apr 09, 2014 5:18 pm
Hopefully Charlie_S will reply, but I think the One Year on the 1965 904 has to do with it being a single cable(?), as opposed to 1964 dual cables and 1966 switch to hard linkage.
1964 Dart GT
PostPosted: Thu Apr 10, 2014 1:02 pm
AFAIK, the 1965 "one year only" status is for the 727 trans- it had dual cables for shifting like earlier units but was the first torque-flite to have a splined output shaft with a "normal" slip yoke on the driveshaft. The 904 was pretty much the same as 64- dual cables, flanged output for a ball & trunion joint, etc. I believe that all 65's also had column or floor shifters (no more pushbuttons).
Whatever parts you get need to be for the "early " (cable shifted) 904. There are quite a few differences between the 60-65 vs. 66-up units. Some parts or assemblies can be swapped, some can't- or require mods to do so.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Thu Apr 10, 2014 1:19 pm
Yes, 1964 was the end of Pushbuttons, but I believe the cable for shifting the 904 is different for 1965, among other small things. Like WagonsRcool said column and floor shifters only for Automatics. I don't know anything about 727's.(Trucks & Taxis?)
1964 Dart GT
PostPosted: Thu Apr 10, 2014 4:06 pm
The only difference between the 64 and 65 904, is the valve body, and the cables themselves. The cables will interchange on the trans, with the correct valve body. The shifter end of the cables and the length is the difference.
PostPosted: Thu Apr 10, 2014 4:43 pm
Just curious, would I be able to buy any 904, and swap over my valve body?
Also whats my best bet as far as a rebuild kit
PostPosted: Thu Apr 10, 2014 5:18 pm
Any cable shifted 904
Haven't bought one for several years, so not sure what the availability is at this time. But there should still be several sources.
PostPosted: Thu Apr 10, 2014 5:49 pm
Torqueflite Patty "Pat Blais" tflitepatty@verizon.net
1964 Dart GT
PostPosted: Thu Apr 10, 2014 10:58 pm
Thanks. I tried the email but it did not work
Is there any way to quickly tell if a trans is a cable, or cable shifted if its out of a car? Sorry never had a 904 out to look at before. Im tempted to find a spare trans to throw in for now if its an easy enough swap
PostPosted: Fri Apr 11, 2014 5:12 am
They are easy to tell apart. A picture is worth a thousand words, but I can't post a picture. Maybe someone else can post one.
PostPosted: Fri Apr 11, 2014 6:33 am
Thanks charlie. I wish I could still figure out my carb issue. Its been sitting for almost a year, after the issue. Then the trans started pouring. Then a wheel cylinder popped. .... thank god it happend sitting in garage, not while driving.. single circuit
PostPosted: Fri Apr 11, 2014 10:03 am
Have you looked at the O-Ring on the dipstick tube?
This article has some good info. and pictures.
http://www.1962to1965mopar.ornocar.com/transtech.html
1964 Dart GT
PostPosted: Fri Apr 11, 2014 12:05 pm
Its either coming from the rear of the pan gasket, or something above the rear of pan
PostPosted: Fri Apr 11, 2014 12:35 pm
solve that problem!
http://www.realgaskets.com/files/popups/popup167.html
1964 Dart GT
PostPosted: Sat Apr 12, 2014 5:53 pm
The cable shifted 904's had a round output flange with studs for the B & T driveshaft & a hole on the left front corner of the case for the shift cable- just one lever for the kickdown. Rod-linkage shift 904's had the splined output shaft (no flange), & two levers on the left side - the kickdown right above the shift lever.
63 Valiant Wagon
225 - 4 bbl
