It is currently Sat Nov 21, 2026 6:05 am
 Post subject: D150 4 speed shifter
PostPosted: Wed Apr 23, 2014 11:34 am
Hey Guys,
I just noticed some differences in shifter locations for the D150. I have an 84 D150 custom. Slant of course and the 4 speed. I was looking around at some pics on the net and I saw an 84 prospector with a 4 speed and the shifter in that truck had a curved long handle and was connected right to the trans tunnel forward up near the dash. Whereas mine has a shorter handle and it sits on a sheet metal pedestal that is attached to the left side of my trans tunnel just in front of the bench seat. Can someone shed some light on this for me. I'm getting ready to order a new vinyl floor for the truck and the location of the shifter cutout may be an issue.
PostPosted: Wed Apr 23, 2014 5:00 pm
a833 was not the only manual tranny offered,
there was a second manual, completely different from the a833, the name escapes me at this moment,, that had a genuine granny gear, I believe it was a top loader..
PostPosted: Wed Apr 23, 2014 6:47 pm
The overdrive transmission is the A833OD and has an external shifter on the left side. The heavy duty 4 speed is the NP435 family and has the shifter in the top cover.
 Post subject: Np435
PostPosted: Wed Apr 23, 2014 6:50 pm
D-150's only got the Np435 and the HD springs since they were the 'load haulers'
The only way to get a shifter for it is to buy another good tranny at a junkyard. Sadly these are boat anchors and typically get tossed with the slantsix as scrap, luckily they used that tranny from the 60s to the late-80's, so there should be one if your local yard has a row of 80's Dodge trucks.
PostPosted: Thu Apr 24, 2014 3:41 pm
?? :? Ok now I'm confused. My truck is a D150 but it has a A833OD, says so on the label on the hood. So maybe my truck isn't a D150? Well its got D150 badges on it.
My delema is if I order a vinyl floor for an '84 D150 is the cutout for the shifter going to be in the correct location. Or since I have the A833 with the shifter located on the side of the tunnel. Should I order a mat for the W100, or W150.
PostPosted: Thu Apr 24, 2014 6:01 pm
the W's are the 4 wheel drive versions
the od a833 is the standard manual tranny for the 80's D-150's, NP435's were also offered.
here is some NP435 info
https://www.novak-adapt.com/knowledge/np435.htm
, when I purchased replacement carpet for my 83 D-150,, I had to cut out the hole for the floor shifter..you can check with the carpet supplier to see how they provide it.
by the way, I am not sure what
means myself,, and I have an 83 D-150,,a833...
 Post subject: Sure...
PostPosted: Thu Apr 24, 2014 7:47 pm
I could see that, although I've never seen one optioned like it, and the junkyards are littered with NP435 or 727 80's D-150's...Typically the A-833OD is seen in the D-100's, it just seems a bit odd they would consider that combination since the A-833OD would not last long with a yard an a half of gravel in the bed (but a 1-barrel 225 and the NP-435 has no problem hauling that load, been there, rode in that).
When in doubt, you can look under the truck at the tranny tunnel and see where the shift hump is located and if there has been any mods done. If the build sticker matches the VIN, then it's a factory job.
PostPosted: Thu Apr 24, 2014 8:06 pm
maybe it is a location thing,, around here,, in the pull aparts,, I have seen exactly one NP435, it was in a D-250, had a heavy duty frame hitch and a rear sway bar,, I got both of those for my D-150..
all the manual tranny D series trucks I have seen are a833's
the a833 is not exactly a slouch..
PostPosted: Tue Apr 29, 2014 6:00 am
I have also seen a few with the 833 (like mine) it can haul just not as much. (I have done 6 200-250lb chucks on concrete once. tranny didn't mind. 32 year old springs did.) Actually I don't think I have seen the other tranny except in manuals. If anything I agree with contacting the company. If it does not specify the tranny it might be a cut yourself deal. I wouldn't assume. I have seen far too many parts places not know anything about the slant 6 and the vehicles that carried them.
(typed while holding a baby. Next gen slant 6er)
PostPosted: Sat May 03, 2014 11:12 am
My 86 has the 833od also.
And according to Brewers Performance it is a Hurst shifter they used with the 833.
So the rebuild kit for the shift is the same for all Husrt shifters that they sell.
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
 Post subject: Correct...
PostPosted: Sat May 03, 2014 11:17 am
This also applies to the cars as well, except for a few years in the 60's where they could be equipped with the inland shifter.
FYI.
With some bench space and a few common tools the hurst shifter is easy to disassemble clean out, replace worn missing parts, lube, and reassemble.
-D.idiot
PostPosted: Sat May 03, 2014 6:38 pm
and here is an article with info on setting up a shifter and linkage
http://www.mobiloil.com/USA-English/Mot ... .aspx?pg=1
