It is currently Sun May 10, 2026 4:48 pm
Post new topic  Reply to topic  [ 1340 posts ]  Go to page Previous 161 62 63 64 6590 Next
PostPosted: Tue Apr 08, 2014 7:29 pm
Awesome work Greg!!
thanks Brian,
good to hear from ya!
tonight was the first time ruster has run since october. this time with no distrubitor or factory oil pump.
still need to tidy up all the wiring and mount the front end & radiator on. plenty of work to do; not sure if it will be done for mason Dixon 2014, but if not I have another slant car I can bring.
pics wil be postted sometime.
PostPosted: Sun Apr 27, 2014 6:33 pm
Success!
Ruster is Now Running On the Megasquirt 3 Control ECU Without Faults.
I still Have some small things to do like wire up the ammeter and re locate the alternator feed wire, but Ruster is ready for some test hits to see if everything is functioning and holds together without throwing belts or catching on fire.
Yesterday I corner scaled it( BIG THANK YOU LOU!!!!!!), then Today I aligned the front end and changed the oil. and gave everything a good pre season once over.
Here are some pics..
The scales revealed that Ruster is still a bit heavier than I would Like, and that my calculations were quite a bit off.
I thought that it would come in near 2088#, however the scales revealed that Ruster was sneakin some wing dings and doughnuts when I wasn't looking!
Scales said 2139#.. some more lightening must be done next winter!
to the track next! To see if the Computer and Timing / Lightening has paid off at all.
 Post subject: 4-28-14 Pictorial Update
PostPosted: Mon Apr 28, 2014 5:55 pm
Well I have been thrashing quite a bit to get Ruster Ready for the mason Dixon Race this year!
I wasn't sure if I would make it, and its still possible that things could go awry.. But I have been working on Getting things installed and Fabbed up on the Car that I really didn't have time to post stuff.
I will Get a test session in this week weather pending.. of course.
But heres' the Pics that I have been withholding from all of you's slant paparazzi's.
Engine Compartment..
Moroso vacuum Tank / Breather.. Mounted behind Drivers Side Front Tire.
eBay Oberg 600 Filter Mounted on the Right Side Behind Front Tire.. makes For easy filter Change/Cleaning and Clean up in the open Area.. A few rags and A Bucket Help alot with this.
Passenger Side Engine Details:
eBay Moroso Vacuum Pump:
I chose to move the Radiator Over to the Right 2' Now that I have the space and flexibility when not using Stock rubber Molded Hoses. (THANK YOU FOR THIS IDEA MARK GOODMAN! GO TEAM GREEN!)
Megasquirt 3 Ecu Mount on an old Michigan Liscense plate:
Trigger Wheel and Hall Sensor Mount details: I had Originally made one(hall sensor Mount) from aluminum, But I had quite a bit of trouble with it and I was chasing my tail a bit trouble shooting, so I broke down and made one from steel.. Maybe one day I will make a billet AL one.. But with no access to a mill or latte it sucks to have to rely on others to do these small bits for you..$$$
0.015" Sensor to tooth Gap.
New Weld Wheels out back to Match The Weld V series' Up front. :-)
Special thanks to:
Will Burns
Edd Jesolowski
Mark Goodman
Mark Ethridge
Seymour Pederson
Ron Hamby
For helping me out with Racecar building type questions and Technical help.
PostPosted: Mon Apr 28, 2014 6:49 pm
You da man Greg! Now with all that new bling on there you need to treat yourself to a new piece of dryer duct for the carb!! :lol: :lol:
You have done a huge amount of work over the winter. I hope it runs well and you can bring it to Mason Dixon.
Rick
PostPosted: Mon Apr 28, 2014 7:52 pm
Lovin' it ! :D
PostPosted: Wed Apr 30, 2014 3:31 am
You are more than welcome. I am always happy to try to help.
Will
PostPosted: Wed Apr 30, 2014 5:58 pm
I think I have to watch out, you'll be in the 11.s easy !!!
Destroked 300 (272ci)
PostPosted: Wed Apr 30, 2014 6:27 pm
that's what you think... I don't believ it until I have 10 time slips with all varying track and weather wind conditions that start with 11.xx.
 Post subject: 5-1-14
PostPosted: Fri May 02, 2014 8:27 am
Well i went to to track and Have some bugs to work out.
I don't even remember what the et's were... just bad/ slow I was struggling to stay in the 12's with High speed misfires etc...
Not sure if its a trigger wheel / Hall sensor error , Maybe the coils need more dwell, or possibly The spark Plugs I used dont work well with this engine combo( the old plugs were removed as they were fuel soaked from Trying to start the car when I first installed MS3/ Trigger wheel)
The Vacuum pump works too well. I have a regulator on Order to tame the vacuum pump, & suck less oil out of the engine. I learned that too much vacuum in the crankcase might not be good. I might have to rework some of the internal valve cover baffling as well. Also I have some of the original (pre Coil on Plug) spark plugs on order too. We'll see if I can get it sorted out.
PostPosted: Fri May 02, 2014 10:19 am
I was just going to post to be careful with the vacuum pump. Get too much and it can draw oil away from the pickup and hurt the crank. I believe the number is no more than 14 inches.
PostPosted: Fri May 02, 2014 10:44 am
Thanks for the insight.
That's why I am going to get the regulator.
One of the track techs was nice enough to spend some time and offer up some suggestions that correlate with yours Dennis.
I am new to all this Vacuum Pump Stuff.. so live and Learn!
(better than living and not learning)
PostPosted: Sat May 03, 2014 10:40 am
LOTS of new changes to that car, so teething is unavoidable. Congrats on getting it fired and to the track! See you M-D, Dr. Ruster, with your Frankenstein or without...
PostPosted: Tue May 06, 2014 2:02 pm
very impressive,,nice work!
PostPosted: Mon May 26, 2014 6:57 am
That looks great Greg. I want to ask you sometime about how the Mega Squirt is configured for your ignition, and what type of coils you are using.
Sam
PostPosted: Mon May 26, 2014 9:44 am
Greg, I too was having a high speed miss when I put the new car together. I went after everything electrical and still had it. Not saying this is your case,, Mine was in the jetting. and not what you would think. Instead of a lean pop, it was too rich. After chasing my tail for a while,and as a old schooler(not having a air/fuel meter) I took a chance and started with metering rods leaning a little at a time. Just a thought..
