It is currently Sat Nov 28, 2026 1:25 am
Post new topic  Reply to topic  [ 23 posts ]  Go to page Previous 1 2
PostPosted: Tue Apr 29, 2014 10:35 am
Yes!
Maybe? :P
Definitely:
http://www.slantsix.org/forum/viewtopic.php?t=38471
I guess so :shock:
BTW, the rear end is an 8.25 says has a 3.21 ratio, that sound right?
1984 D150 with a 225 .30 over, A904. Dash choke, points conversion, new carb, new camshaft, new lifters, new pistons, new oil pump, balanced crank.
PostPosted: Wed Apr 30, 2014 8:32 pm
Could be.....pretty high for a truck.
You should be able to get some really good mileage empty.
PostPosted: Wed Apr 30, 2014 10:18 pm
I agree with Ted. Unless you only do light hauling or occasonal heavy hauling, 3.21s are a pretty high ratio for a truck. 3.55 would be beter for a hauler.
PostPosted: Thu May 01, 2014 9:12 am
Would I be able to find and swap rear ends with another donor truck perhaps?
PostPosted: Thu May 01, 2014 10:35 am
Sure. Find any D-series pickup through the early 90s and the entire rear axle and leaf spring assembly will be a bolt in. If you do this, I recommend grabbing the leaf spring hangers from the donor vehicle and replacing the front and rear leaf spring bushings while you have them easily accessible.
PostPosted: Thu May 01, 2014 11:50 am
So my would my current axle allow me to upgrade to 3/4 ton springs or only the lower ratio one? Or both? 20 questions...
PostPosted: Thu May 01, 2014 12:15 pm
(1) so long as the leaf spring hangers match the leaf springs and the frame of the vehicle, you can put any springs you like on your truck, provided the springs are for a D series pickup (or Ramcharger, since it is based on the D series). Be aware that you should really match the coil spring ratings with the leaf springs.
(2) you can swap any gear you want into your axle, provided the gearset is designed for the carrier in your axle and the spline count is correct
(3) You can also swap any axle you want into your truck, provided the spring perches are set at the correct width for a D series pickup.
PostPosted: Fri May 02, 2014 10:51 pm
Gotcha on 1 and 2 but what is a spring perch?
Googled it, still confused - is this related to angle?
Users browsing this forum: Google [Bot] and 7 guests
