It is currently Sat Feb 22, 2025 12:37 am
PostPosted: Thu Mar 06, 2014 8:24 pm
I will be installing a GM HEI 4 pin module. I'm going to locate it away from the engine heat. Will mounting it say 6.5 feet away from the distributor affect it's performance. I've got an A100 pickup. That's about the distance to under the dash.
Mostly Old Parts And Rust
1933 Desoto Coupe 426 Hemi
1946 Dodge dumpbed pickup 2.5 Turbo 4cyl
1964 Dodge A100 pickup 273 automatic
2002 PT Cruiser Woody edition
PostPosted: Thu Mar 06, 2014 8:34 pm
I have mine mounted just behind the alternator and it works just fine for me. Be sure to use heatsink compound and a heat sink and you should be good.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1965 Plymouth Barracuda
1967 Chevy Camaro
PostPosted: Thu Mar 06, 2014 8:35 pm
6 Pack Dart
GM mounted them inside the distributor at the back of the engine, you might be to cautious. :lol:
Richard
PostPosted: Thu Mar 06, 2014 9:09 pm
Yeah, I know. GM used them in vans a lot of heat. Just thought keeping away from heat would be better, But what do I know ?
PostPosted: Thu Mar 06, 2014 9:13 pm
And there are basically no inner fenders to speak of on an A100. Thought of mounting it to the outside of the battery box. Might be a pain under the dash.
PostPosted: Thu Mar 06, 2014 9:40 pm
I think if you make a bracket you should be able to mount it and the coil where the old coil used to be. I thought about it but decided easier access.
2006 Jeep Commander
2013 Chrysler 200
1964 Valiant 4 Door
1967 Chevy Camaro
PostPosted: Thu Mar 06, 2014 10:43 pm
Here is a bracket I make for that set-up.
Steve
http://www.ebay.com/itm/370906866355?ss ... 1555.l2649
PostPosted: Fri Mar 07, 2014 2:10 pm
Closer to the distributor is best, it reduces the chance of RFI from disturbing the signal from the pick-up to the module. They are designed to withstand alot of hear, be more cautious of mounting it somewhere it is insulated to dissipate heat, stays dry, and has a good solid ground source.
"if it aint broke, fix it till it is"
78 Plymouth Volare Super Six wagon
89 Volkswagen Golf GTI 16v
92 Chevrolet K1500 5.7
98 Ford Escort ZX2 zetech
PostPosted: Sat Mar 08, 2014 10:22 am
That's what I wanted to know. I may build a sealed metal box with a heat sink . And use reflective insulation to cover the box. Mount it all to the back inside of the engine box.
PostPosted: Tue May 20, 2014 5:55 pm
Steve
Just ordered one...Thanks!...but I am using it on an AMC!
PostPosted: Tue May 20, 2014 6:50 pm
See here for offer on heatsinks
http://www.forabodiesonly.com/mopar/sho ... 1969545173
I'll send one for shipping.
Dave
1972 d-100 parts truck
PostPosted: Tue May 20, 2014 7:56 pm
Thank you sir !! On the way in the mourning !!
Steve
PostPosted: Tue May 20, 2014 10:57 pm
The original ACDelco HEI heat sink piece has part number 10474610, pricerange $12-15, looks like this:
For V8 applications, there is a guy on eBay who makes a bracket/heat sink, to mount the module on the underside of the Mopar distributor, but there's no room for that on a SL6.
Olaf
Aspenized
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 61 guests
