It is currently Fri Nov 20, 2026 7:34 pm
PostPosted: Fri May 23, 2014 12:19 pm
This is a question for those of you who have 8 & 3/4" rears in your cars. Is there a train plug in the case of them? This Ford rear, which has a separate pumpkin, from the late 80's has none. When I tipped the rear up on end after pulling the axles, something akin to mud came out. It certainly looked as if it had never been changed. How could it with no drain plug?
I am wondering if it is reasonable to put a drain plug in the case, and where it is on the Mopar units. I could drill a hole in the case and tap it for an NPT plug.
I do not know if other rear ends with removable pumpkins had drains in the case. Thanks for any feedback on this.
Sam
PostPosted: Fri May 23, 2014 1:28 pm
Looking down drive shaft to pumpkin it is on the left, or in other words in the passenger's side about half way between top and bottom of casting.
PostPosted: Fri May 23, 2014 1:52 pm
That sounds like the filler hole, which this has. Is there a drain as well?
Sam
PostPosted: Fri May 23, 2014 2:20 pm
6 Pack Dart
There is no drain hole on Ford 8" you must partly remove all flange nuts and pull center section partly out to drain.
Richard
PostPosted: Fri May 23, 2014 2:27 pm
or get a small hand held cheapo suction / transfer pump and get suckin out the filler hole..
otherwise you will need to add / weld in some sort of drain if you want one.
PostPosted: Fri May 23, 2014 2:42 pm
Car Model: '23 T-bucket
I'v got a '59 Chevy rear that has both a fill port and drain plug in the main housing. Drain plug is bottom center, while the fill port is centered at the back, about 1/3 the way up from the bottom.
You may be able to drill/tap the bottom center of the main housing for a plug, but do make sure it won't interfere with the ring gear on the inside.
Roger
PostPosted: Fri May 23, 2014 4:35 pm
6 Pack Dart
I think you will find the housing is too thin to just drill and tap. You should if you want a drain plug empty the housing, clean all lube traces and weld a plate to be drilled and tap it for drain plug.
Richard
PostPosted: Fri May 23, 2014 6:12 pm
Thanks all. I will likely make no changes. I probably won't live as long as this axle is old now.
Sam
PostPosted: Fri May 23, 2014 11:08 pm
Moser makes some very nice fill/drain plugs that come with weld-in bungs.
PostPosted: Sat May 24, 2014 2:48 am
Hmmmm.
Sam
PostPosted: Sat May 24, 2014 12:39 pm
There is no drain plug, and not much room to snake in a small tube to suck oil out is a Suregrip. I purchased a "rear end sucker outer", yeah I get it, innuendo intended..., and the tube would not reach very deep into pumpkin; waist of money.
