It is currently Thu Jun 25, 2026 5:49 am
PostPosted: Fri Jun 13, 2014 4:22 pm
I have a stock single barrel Holly carb on my 71 Dart with Slant 6.
I did a 30 over bore and RV cam. What size Jet do you recommend
to replace the stock jet with?
Any advice will be appreciated.
Darren
 Post subject: What Holley?
PostPosted: Fri Jun 13, 2014 5:49 pm
There were 2 different Holley 1 barrels available...
The original Holley 1920 for your car with the front hung float bowl would do great with a #57 or #58...
If it's a later Holley 1945 with the dual floats inside the carb body...install a #61 and reset all the linkage per the rebuild kit instructions as a 1976 Car.
PostPosted: Tue Jun 17, 2014 10:09 pm
I agree with the 57 58 size jets for the fron hung float holley. I run bigger but here in Bristol tn. with headers and good exhaust it likes it.
Jess
PostPosted: Wed Jun 18, 2014 4:40 pm
For a little more consistent economy I run a #56 with 2.5" exhaust. It bumps the mileage on short 4 to 8 mile hops from 20 to 22.5 mpg. On trips it jumps way up there.....25 mpg plus if I don't drive too aggressively!
That is comparing it to a #57.
