It is currently Sat May 30, 2026 11:07 am
PostPosted: Fri Jun 20, 2014 4:16 pm
i'm piecing this back together from a roller. the slant is 65 and the pushbutton tranny is I assume 65. no external filter.i just dropped in the eng/tranny. I see the bracket would require offset insulator. I have bracket like in my 65 slat dart. bracket ( rest s directly under where it bolts to tranny)'
I see o reillys offer an offset bracket, where it goes in bracket it has 1 bolt instead of 2. can I mke this insulator work with my bracket???????
wht do I TRY to piece these things together!!?????? LOL
my email is billbarbee222@yahoo.com and ph is 417-350-5951 evenings before 8 p.m. central time please
 Post subject: huh??
PostPosted: Sat Jun 21, 2014 6:55 am
what I wonder if the 63 dart used a different tranny crossmember????? could I have a 65 pickup trans?????? or????? any insight will be appreciated....
PostPosted: Sat Jun 21, 2014 7:53 am
I'm 99% sure the cross members are the same. 1963 and 1965 904 transmissions are different, being that '64 was the last year for pushbuttons. 1965 is a (1) year only cable linkage to a column or console. In 1966 they went to hard linkage.
1964 Dart GT
PostPosted: Sat Jun 21, 2014 10:11 am
i measured the 904 in the 65 dart (slant) , tailshaft if longer. probably B body or truck tranny? wondering if they used an offset corssmember insulator, or if crossmember sat directly under the mounting holes of the trans?????
PostPosted: Sat Jun 21, 2014 5:18 pm
get the #'s off the side of the transmission and post them!
1964 Dart GT
 Post subject: numbers
PostPosted: Sun Jun 22, 2014 6:20 am
not aware of any numbers on tranny except vin on 69- up cars..... trans is in car.... another 65 904 for 273 65 cuda sitttin on floor,,,,,, I see no numbers on it??
PostPosted: Wed Jun 25, 2014 2:23 pm
After reading these posts I had to grab my tape measure and check my trans
out. I have a 62, 64 and 65 slant a body transmissions. The 62 and 64 are the same length-11 3/4 from bolt face to the end of tail shaft housing. The 65 is 12 1/2 but they are all the same length from bolt face to the trans mount bolt center. 6 3/4 in. Interesting?
