It is currently Wed May 13, 2026 12:05 pm
PostPosted: Wed Oct 15, 2014 6:32 am
anyone know if these drums will fit an A 8.75
http://www.rockauto.com/catalog/moreinf ... cc=1494750
the inner drum size of 10 inches looks right
here are some photos of what the drums look like on the 8.75 that I picked up a few years ago, the flare where the drum fits over the backing plate is different?
https://www.flickr.com/photos/13718356@ ... 769203052/
I'll get the ID of the drums measured, but they look like the have been cut pretty thin. That is why I am looking for replacements.
along that, is the .090 over sized the correct limit as shown on the RA listing?
PostPosted: Wed Oct 15, 2014 7:22 am
That is a front drum. Won't work.
PostPosted: Wed Oct 15, 2014 8:11 am
Charrlie, I trust your info but the RA part listing says:
CENTRIC Part # 12363007 C-TEK Standard Brake Drum-Preferred; Does Not Include Wheel Bearings
Front; Front Drum brakes; Rear Drum brakes; 10" Drum
any ideas on another source?
PostPosted: Wed Oct 15, 2014 9:58 am
That listing means "Front" with front drum brakes, and 10 inch rear drum brakes. You can tell the drums are wrong for the rear, as the rear drums should be 10 inch by 1 3/4 wide.
As for locating them, just have to keep searching. They are hard to find. I think I got the last 2 rockauto had, last spring, when I built the rear for my Valiant. They do show up on e-bay from time to time, but are usually over $100 ea.
PostPosted: Wed Oct 15, 2014 10:33 am
ok now I see that the RA drums have a 2 in + friction surface
you da man :)
PostPosted: Sun Oct 19, 2014 12:27 pm
Which brakes are you going to use John? SBP or LBP?
PostPosted: Sun Oct 19, 2014 1:23 pm
LBP
PostPosted: Mon Oct 20, 2014 2:38 am
That will depend on if you redrill SBP axles or have LBP axles made for B/E body brakes. B/E body 10" brakes are 2-1/2" wide and use a different end spacing from the wheel bearing to flange.
