It is currently Thu Nov 19, 2026 11:09 pm
PostPosted: Mon Oct 20, 2014 7:24 pm
I have been running a protonix unit which has gone bad. When I got the unit they were the only one the market . Now Mallory , msd, acces, all make them. I have been reading that the protonix units have gone down hill. Does anyone have a suggestions one which one to use
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Mon Oct 20, 2014 9:38 pm
None of the above. Start with an electronic distributor and do the HEI upgrade.
PostPosted: Tue Oct 21, 2014 4:27 am
My pertronix ( I'm assuming this is what you mean) went bad in my '72 Valiant not too long ago and I switched back to points.....I never replaced the pertronix and I have been getting Standard brand points from Rock. I eventually will go with Dans advice.
PostPosted: Tue Oct 21, 2014 4:13 pm
I have on, with a orange Cdi box. I am having a hell of a time wiring it. I have wired per the wire diagram checked my coil replaced my ballasted resister and still don't have spark at the coil. Also my other dizzy as been balanced and reweighted. Any suggestions
225+0.080 at 10:1
268cam
holley 390
clifford headers
8 3/4 355's lsd
kh brakes
electronic ing
PostPosted: Wed Oct 22, 2014 1:15 pm
My suggestion is to follow Dan's advice & go with the HEI system- it's fairly cheap, effective, & reliable. Hook everything to the car but don't install the distributor yet. Fit a gap-type spark tester to the coil output lead, turn the ign key ON & spin the dist by hand- should have lots of spark. Install the dist, fire it up, set timing, then forget about it.
63 Valiant Wagon
225 - 4 bbl
