It is currently Sun Nov 15, 2026 10:47 pm
PostPosted: Sun Nov 23, 2014 7:46 pm
I've been occupied with other things for about two years now... Is anyone currently making an adapter for slant six bolt pattern to small block?
Sorry if this seems redundant, I have spent quite some time searching, but to no avail.
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
PostPosted: Mon Nov 24, 2014 8:00 pm
The deafening silence must mean that no, nobody currently is.
PostPosted: Mon Nov 24, 2014 8:47 pm
Nope, nobody is currently reproducing it due to a lack of interest. Hit up Mopar specialty yards. As of about 2010, wildcat was asking about $200 for a complete factory setup. BUt then you have to add shipping for a cast iron adapter. You probably can make your own if you are reasonably competent with a marker.
PostPosted: Mon Nov 24, 2014 8:53 pm
Which small block, This is for the Chevy pattern: http://www.wilcap.com/225350.PDF
PostPosted: Tue Nov 25, 2014 2:37 am
wvenables was having one made a while back. Maybe his machinist kept the pattern.
The one I had made is in the hands of Dart 270. It was made by Team Green. Last I knew he said they were not going to make any more, but that may have changed.
PostPosted: Tue Nov 25, 2014 12:58 pm
Wayne took my aluminum / slant 6 to small block Lakewood blow proof plate, and had 2 steel ones made. I believe the guy has the cad files.
What are you trying to do?
Here is the link;
http://slantsix.org/forum/viewtopic.php ... r&start=15
Rick
PostPosted: Tue Nov 25, 2014 5:35 pm
I'm a "mopar or no car" and I don't put anything else anywhere near my stuff...
PostPosted: Tue Nov 25, 2014 5:45 pm
I am wanting a(n) A-500/nv3500/getrag 238/np535 behind my slant in a W150.
The NV3500 only has a bellhousing for a small block. The G 238, the same - it's a 6 speed with nice close ratios from 1-6. The NP535 isn't well known, but it should fit nicer than almost anything else. It was also called an NV2500.
There is also a possibility of using an AX15 - for which there is also a SB Mopar bellhousing.
PostPosted: Wed Nov 26, 2014 8:41 am
I have both the adapter and crank adapter as eventually I want to replace the 904 in my 87 slant-quipped D100 with a 500/518.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Wed Nov 26, 2014 9:48 am
The Getrag 238, was that also the six speed used behind the 3.7 v6 in 3rd gen daks?
PostPosted: Thu Nov 27, 2014 3:18 pm
I think so. It was also used in full size trucks.
