It is currently Sat May 16, 2026 6:41 am
PostPosted: Thu Jan 01, 2015 7:57 am
have 66 D100 slant 6 -225. It appears from reading the forum, it may be a better idea to rebuild the original 6 bolt oil pump vs buying a new one. Is that always the case or s there a new pump that would be better than an original? This is just a stock rebuild for daily driving.
appreciate any advice regarding oil pump.
Metal Turkey
PostPosted: Thu Jan 01, 2015 8:08 am
If you have a good pump that has a good gear and Camshaft to match it, I would never change the pump.I would try and keep those happy gears together forever. Clean up the relief valve assembly and check the clearances(Factory service manual for specs) and you should be good to go. Do you know what your oil pressure was before?
Rick
PostPosted: Thu Jan 01, 2015 8:32 am
Thanks for the advice, the engine had not been run for 26 years, and I did not start it before starting the tear down, so I don't have any oil pressure bench mark. The rebuild shop said the engine looked to be in good condition when I dropped it off. the oil pump does not show any visible signs o repair.
PostPosted: Thu Jan 01, 2015 8:35 am
I sent ya a PM.
PostPosted: Thu Jan 01, 2015 12:44 pm
To give you a bench mark the slant six in Australia uses a different oil pump casting...it has fittings and oil lines running to a remote oil filter on the opposite side of the engine. This is due to steering box clearance in right drive vehicles. There is no new oil pump available,Chrysler Australia have been gone for decades. Every Slant that gets rebuilt in Australia has a used oil pump....as long as you use good rebuild practices and check pump tolerances then there is zero issue.
PostPosted: Thu Jan 01, 2015 3:09 pm
I wish the Aussie casting was still available. It would be nice to run remote oil pressure lines without needing an adapter.
Rick
PostPosted: Thu Jan 01, 2015 5:25 pm
So where can a guy get the internals or whatever is necessary to rebuild an oil pump?
--> The Diesel Corvette <--
 Post subject: Junkard...
PostPosted: Thu Jan 01, 2015 6:33 pm
There really isn't any place to get the internals, only the gaskets are available...usually you end up like me with a couple dozen cores from stripping free engines or grabbing what you can at the junkyard, you then put together the set of rotors, rings, springs for the best clearances you can get....Out of the last 15 junkyard pumps I've gotten I had to toss 5 because the internals looked like they digested some carbide coffee grounds and had to be pitched...that being said, since there are literally 3 different pumps with different rotor thicknesses, you won't be able to match much with other pumps with those parts....the oem pumps have better hardness gears and are good to swap onto the "new" Melling pumps...
PostPosted: Thu Jan 01, 2015 8:51 pm
Keep the oil pump drive gear......
PostPosted: Fri Jan 02, 2015 4:52 am
If your old stock pump is not damaged, it will be totally fine. I have not used a new or rebuilt pump on my last 2 motor builds and oil pressure and delivery is perfect. I just save old pumps from torn down motors that were not damaged due to bearing or other major failure.
PostPosted: Sun Jan 04, 2015 2:06 pm
I have a factory RHD oil pump and fittings; send me a PM if you'd like to buy it.
PostPosted: Sun Jan 04, 2015 7:02 pm
It is basically the same oil pump, without the filter boss.
I never liked the oil flow restriction, caused by the right angle brass fittings they used but a fitting change and some porting work would likely improve the flow thru one of these pumps.
 Post subject: pump offer
PostPosted: Mon Jan 05, 2015 6:28 am
Thanks for the offer, but getting my old pump worked over by Doctor Dodge
PostPosted: Sat Jan 17, 2015 10:33 pm
I got the complete kit from Rockauto. $20
PostPosted: Sun Jan 18, 2015 8:35 am
Got a part number?
I can find complete pumps or seals and gaskets. No rebuild kit.
Users browsing this forum: Google [Bot] and 11 guests
