It is currently Mon Nov 16, 2026 6:23 pm
PostPosted: Sat Jan 10, 2015 6:39 pm
So with a street / strip 904 trans , supercharged 63 wagon engine is older large dia crank .
Lock up or non lock up ?
What year trans should I look for ?
And with 27" rear tires and 3.64 or 3.70 gears what would you recomend for torque converter size ?
1963 Plymouth Valiant Wagon
PostPosted: Sat Jan 10, 2015 7:03 pm
Earlier SL6 cranks have the smaller converter pilot hole... not the "large diameter" so you need to confirm what crank pilot size you have. ( a 63 would have come from the factory with the small pilot)
In general, a non lock-up is better for a performance set-up.
Common Mopar rear end gear ratios are:
2.93 / 2.94
3.21 / 3.23
3.55
3.73
3.91
4.10
If the transmission has a 1 to 1 final drive then a 3.23 or a 2.94 are good choices.
PostPosted: Sat Jan 10, 2015 7:51 pm
Thanks
yes I ment not original engine newer with larger dia hole .
As for rear end I have to confess I am using a ford 9" ..
PostPosted: Sun Jan 11, 2015 8:38 am
Thanks
Good info...
It is nice that you have the later "large pilot" crank, that opens-up more options for transmissions & converters.
PostPosted: Mon Jan 12, 2015 5:01 am
I am going to look at a /6 904 transmition he thinks is a 1967 with no converter all other shields are there and it's a great core if it's the large pilot non lock up..
This is my understanding to ID a 904 trans that's sitting on the garage floor no vehicle to help. ID just a craigslist / swap meet sale one stranger to another ...
Input shaft spline count
18 splines it's for the early small crank pilot hole ?
27 splines non lock up large newer pilot hole
26 splines lock up 1978 and end of shaft has a tip that's smooth no splines
Is there any other ways to id that I can do on the spot thanks
PostPosted: Mon Jan 12, 2015 11:22 am
Converter size "RPM's" ?????
1963 wagon
70% street 30% drag , rear gear 3.33 ,3.40 , 904 trans trans go2 , supercharged /6 with 480. To 500 lift cam , 27" rear tires
Just lookin for opinions on size and brand exact cam to be chosen before converter is ..
Thanks all :-)
Users browsing this forum: Ahrefs [Bot] and 3 guests
