It is currently Wed May 13, 2026 4:38 pm
PostPosted: Sat Dec 20, 2014 7:58 pm
Car Model: 1974 Dart Swinger 225
Has anyone found a wrench that is good for opening and closing the bleeders on the front drums of the "9-inch" brakes (on a '74 Dart in my case)? I bought the Autocraft one from Advance Auto Parts and it's too straight. My regular 5/16 box wrench is pretty short, but I still can't get it in there. The Lisle wrench from Amazon looks like it might have a better angle, but it's hard to tell from the picture. What works for you?
PostPosted: Sat Dec 20, 2014 8:09 pm
How about a 1/4" drive ratchet with an extension and a 1/4" socket?
PostPosted: Sun Dec 21, 2014 12:12 am
Break it loose with 6pt small socket.
Then you can use open while bleeding.
Fully tighten with socket.
PostPosted: Sun Dec 21, 2014 8:37 am
There is an Snap-On type that is made for this, PN S8184. There are several for sale on eBay; here the least expensive one but the bidding is up in 9 hours; there are others for more $$.
http://www.ebay.com/itm/SNAP-ON-TOOLS-5 ... 1239930625
It is still in the catalog by the way; page 542.
PostPosted: Sun Dec 21, 2014 10:14 am
Then switch over to Speed Bleeders! http://www.speedbleeder.com
1964 Dart GT
PostPosted: Sun Dec 21, 2014 11:19 am
Take a torch and bend the wrench to work for what you need.
Fast is fine but accuracy is final. You have to learn to take your time ... in a hurry
- Wyatt Earp
PostPosted: Sun Dec 21, 2014 3:51 pm
Thanks for all the replies. I actually tried bending the wrench I have. I looked around and some said do it hot, some said cold. I don't have a torch, so I just put it in a vise and squeezed. It might have worked, but I tried to go a little too far and cracked it. Lesson learned: practice on the end you don't need, before doing the end you need. <facepalm>
+1 for the speed bleeders link, by the way. Cool idea.
 Post subject: Speed Bleeder
PostPosted: Tue Jan 20, 2015 7:03 pm
Just took a look at the Speed Bleeder link... Definitely gonna get some of those! Thanks for the heads-up!
PostPosted: Wed Jan 21, 2015 5:45 am
That's all you need right there.
PostPosted: Wed Jan 21, 2015 8:00 am
I'm sure emsvitil is right, but I bought the Snap-On bleeder wrench off eBay and it really made the job easy.
