It is currently Mon Jun 15, 2026 11:31 am
Post new topic  Reply to topic  [ 38 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Feb 27, 2015 12:32 pm
Are you making sure the batteries are charged before you try starting the car?
PostPosted: Fri Feb 27, 2015 12:47 pm
The top row are all tight but the bottom kind sort of
PostPosted: Fri Feb 27, 2015 12:49 pm
And it's only one but no didn't check since I brought it new today
PostPosted: Fri Feb 27, 2015 6:24 pm
Would the fuel not getting to ALL the cylinders cause it to start and stop so fast?
PostPosted: Fri Feb 27, 2015 7:01 pm
I'm sorry, I thought the issue was slow cranking and no starting.
You should make sure to charge the new battery or at least test that it has charge.
So, the engine is starting and then stopping or just cranking slowly, please clarify.
brian
https://tinyurl.com/yynpj4v2
 Post subject: update
PostPosted: Sun Mar 01, 2015 9:36 am
Both. But now after new starter and battery. Also took headers off and put in stock exhaust manifold with the 4bbl. Spins hella faster then it did but no start still. Only a pop and sounds like I hear something sucking .
 Post subject: ok
PostPosted: Sun Mar 01, 2015 9:45 am
Now you have her spinning...
You need to have fuel, spark and proper ignition timing.
Pop a plug, is it wet with fuel?
Do you have a spark tester? You test the old fashioned way by pulling a spark plug, reconnect to its plug wire, lay it on the fender well and crank it over to see if it sparks at the electrode.
If it's getting fuel and has spark, then check the timing. Get the front most piston (#1) to TDC (on the compression stroke) and pull the distributor cap, see if the rotor is pointing anywhere near tower 1 (where the #1 plug wire goes). There are many threads on this board for finding TDC.
Do the spark and fuel tests first, might be simple.
brian
PostPosted: Sun Mar 01, 2015 7:09 pm
"did hear something sucking"? Did you install the distributer at #1 cylinder compression stroke, or 360 degrees off at the exhaust stroke? (Ask someone who learned the hard way. ) :oops:
Users browsing this forum: Amazon [Bot], Bing [Bot] and 3 guests
