It is currently Mon May 04, 2026 12:11 am
PostPosted: Tue Mar 17, 2015 8:57 pm
I brought an aftermarket oil gauge and none of the adapters fit on the oil pump housing. Somebody help me with this issue.
PostPosted: Tue Mar 17, 2015 9:04 pm
Are none of the adapters supplied a 3/8" npt? If not none of them will fit. You can "T" off the spot with some pipe fittings that will allow the oil sender light sensor, and the gauge to function simultaneously.
 Post subject: pipe fittings
PostPosted: Tue Mar 17, 2015 10:38 pm
These should be standard SAE npt pipe fittings, I'm surprised they aren't included with the kit. Are they metric or something?
https://tinyurl.com/yynpj4v2
