It is currently Thu Jun 11, 2026 4:15 pm
 Post subject: EFI Fuel Line to tank
PostPosted: Wed Mar 18, 2015 6:13 pm
On my 1970 D100, I am considering running EFI fuel line from the fuel pump to the new tank in the bed (behind cab). I want to remove the hard line that is old and questionable. I can run it in the C of the frame to protect it. The thought is to simplify it and eliminate extra unions. I would do this along with the forum mod to the carb.
I know I can't take it to the drag strip this way, but it is a slant six truck LOL. Will this be safe and reliable?
Thanks, Craig
PostPosted: Wed Mar 18, 2015 10:17 pm
You mean rubber hose? It was never meant to run that long. It may work but it's iffy at best. Plus... it's quite expensive, it certainly won't be cheaper vs making your own hardline.
You don't have to make the hardline one long piece, you can make 2-3 more convenient pieces and join them with short sections of hose and clamps.
If you want something flexible to be a bit easier to run then use stainless braid teflon hose. That certainly won't be cheap either.
PostPosted: Thu Mar 19, 2015 9:28 am
I can remake the hard line if it is a must. I just don't like all of the unions as they are spots for potential leaks.
Boats use flexible lines over those lengths as standard practice.
My thought was the EFI fuel line (Gates Barricade Brand) is rated for much higher pressure than the fuel pump will deliver so no potential pressure failures. The EFI fuel line also has built in abrasion resistance.
But if this is unsafe - I will use the hard line.
Thanks, Craig
PostPosted: Thu Mar 19, 2015 3:52 pm
Scraigallen, the fuel pump will suck fuel from the tank, so the hose will be at atmospheric pressure or a vacuum pressure (if you don't have a fuel pump in the tank). Long rubber hoses can collapse on vacuum, and starve/damage your pump (not good). There should be no problem with few unions, the pressure is going to be low anyway.
/6 Dodge Charger 69
Image...there's nothing like using the "Search" link above to solve most of your problems...
PostPosted: Thu Mar 19, 2015 4:54 pm
I doubt it will collapse. This is small diameter relatively stiff hose. I've used thinner clear vinyl pvc hose for testing with an efi fuel pump (hose to tank through the filler neck, pump laying at floor by the door) and it was just fine.
PostPosted: Thu Mar 19, 2015 7:54 pm
Boats don't often run fuel lines on their bottom attached to keel, and ride over rocks, snow & ice, brush, trashcans, traffic cones and whatever else that can kick up and snag a line.
Use metal, perhaps one of the fuel line manufactures has one all pre bent that will clip right into place. If not it is not hard to run several lengths of stock flared tubing fastened together. These lengths won't leak when tightened sufficiently.
PostPosted: Fri Mar 20, 2015 4:06 am
It can't be more than 10-12' from the tank in the bed to the engine. I would run aluminum line and not have any unions. Rubber at each end. 2 cents for ya. :lol:
Rick
 Post subject: Ni-Cu?
PostPosted: Fri Mar 20, 2015 6:56 am
Why not use copper nickel line; it's easier to bend and still rigid. I know they use this for tranny and brake lines.
brian
https://tinyurl.com/yynpj4v2
PostPosted: Fri Mar 20, 2015 11:06 am
I used brake lines. There cheap and If you get the right ones you don't need a tool to bend them. Just make sure to label them as fuel lines and get the right size.
~Nic
PostPosted: Fri Mar 20, 2015 7:32 pm
I like the copper nickel hard line idea. Thanks.
I think I will head in that direction.
PostPosted: Mon Mar 23, 2015 3:08 am
It is very nice stuff but the price in the larger sizes is 3 times as much as aluminum for shorter lengths. I think 25 feet of 3/8 or 5/16 aluminum is under $20 at Summit. Good luck!
Rick
PostPosted: Mon Mar 23, 2015 11:23 am
I wonder if pirating fuel lines, or sections of fuel line, from a late model junkyard vehicle would be practical?
'78 Volare 225
'67 Charger 318
PostPosted: Thu Mar 26, 2015 5:15 am
I used 3/8th" brake line and bent it to fit all the way from the tank to the AN flex line for the fuel rail. It has worked fine for ten years. 5/16ths for the return.
Sam
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
