It is currently Mon Nov 16, 2026 5:05 pm
PostPosted: Sun Mar 22, 2015 8:36 pm
I ordered one of those fancy new pan gaskets Dan recommends and installed it in my brother's Duster today. Mopar part no. 4295875AC. I took some pictures before I installed it so people could see what the fuss is about. I have to say that this is a VERY nice gasket and worth the money! It is a stiffer gasket than the old cork ones, but has very nice raised lips around the perimeter and around each bolt holes.
I am holding the gasket straight out from my fingers and it is stiff enough to not flop down. Good stuff!
Close up of the raised sealing lips on the perimeter and around the bolt holes:
I recommend these for anyone replacing a pan gasket in the future.
 Post subject: SlantSixDan...
PostPosted: Sun Mar 22, 2015 9:09 pm
I read Dan's recommendation and didn't hesitate, I have that gasket as well, great stuff. No sealant necessary.
brian
https://tinyurl.com/yynpj4v2
PostPosted: Sun Mar 22, 2015 10:41 pm
How many times can you use it?
PostPosted: Sun Mar 22, 2015 10:55 pm
I will guess far more than the cork or rubber kinds. Definitely more than once.
PostPosted: Sun Mar 22, 2015 11:02 pm
Thanks Reed and Dan. Looks great.
PostPosted: Mon Mar 23, 2015 5:41 am
I am out of the loop on this one. Where do you get them, and what are they called. Thanks.
Sam
PostPosted: Mon Mar 23, 2015 7:26 am
I got mineon ebay, but you can get them from the dealer. Mopar part no. 4295875AC.
They are called the transmission pan gasket.
PostPosted: Mon Mar 23, 2015 9:18 am
Sam: http://www.slantsix.org/forum/viewtopic.php?t=31863
PostPosted: Fri Mar 27, 2015 6:05 pm
I have one of them. No sealant needed. And I have used it many many times. I used to have tranny leaks, and emptied that pan more than I want to say. But I say, if you don't have it - get it if you can.
