It is currently Sat May 16, 2026 3:36 pm
Post new topic  Reply to topic  [ 34 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Tue Apr 07, 2015 7:22 pm
How hard would it be to rebuild the canister?
Activated charcoal is easy to find,
I'm not so sure about taking the canister apart.......
PostPosted: Wed Apr 08, 2015 3:04 am
As soon as you turn off the ignition open your hood, say when you stop for gas.
Next when you start your car it should start ok.
PostPosted: Wed Apr 08, 2015 9:16 am
What application did you use to look up that number?
Looks like it is 1985-1992 Subaru part.
PostPosted: Wed Apr 08, 2015 11:24 am
Here is the part at autozone much less
http://www.autozone.com/engine-manageme ... 29438_0_0/
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Wed Apr 08, 2015 1:07 pm
I can't speak knowledgeably about this particular part, but in broad general, y'wanna buy the same part two and three and twelve times? Buy "Duralast". It's virtually all garbage.
PostPosted: Wed Apr 08, 2015 1:10 pm
I hate autozone :roll: :roll: :roll:
PostPosted: Wed Apr 08, 2015 3:57 pm
So Well's products are no good either, ok.
Rock auto has SMP canister STANDARD MOTOR PRODUCTS CP3034
for 148.79
Summit racing has it 149.97 and free shipping.
Or you can get it from Auto parts Today and pay 332.30 (':shock:') http://www.autopartstoday.com/item.wws? ... S&weight=5
Who would pay that?
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
 Post subject: price differentials...
PostPosted: Wed Apr 08, 2015 6:15 pm
It is truly amazing what people (apparently) get away with on the internet with their pricing.
I was just looking at a Marvel Avengers 10 DVD set in an aluminum briefcase, with various things, a mock (I hope) tesseract for my daughter. Amazon has it for $122 bucks and free two-day shipping, but also lists various vendors who sell used sets...one was asking $280 plus $4 shipping for a used set as a "collectible - like new"....hard to believe. It is always worth looking through at least 3 or 4 vendors to find the best prices.
brian
https://tinyurl.com/yynpj4v2
PostPosted: Wed Apr 08, 2015 7:43 pm
Car Model: 1977 B100 Van
"Hey, I like that paint job you got. What they call that--sorta a cross between Piss Yellow and Puke Green, ain't it?" -- Bob Falfa
PostPosted: Thu Apr 09, 2015 1:30 pm
thanks Nomad,
I like this one:
http://transamcountry.com/community/ind ... ic=62258.0
 Post subject: wow
PostPosted: Thu Apr 09, 2015 2:16 pm
Yeah, Greg, that guy did a great job.
The only reason these things are expensive is because they can be. plastic and charcoal, maybe some sheet metal...geez, Louise.
PostPosted: Thu Apr 09, 2015 5:35 pm
Those are some great links to canister "rebuilds". One thing that isn't mentioned is the purge valve -- the guy on the Jeep site went looking for a faulty vacuum diaphragm and didn't find it, but there is such a diapragm in the purge valve. If the purge valve is faulty (torn or hardened or holed diaphragm, for example) and doesn't work, there'll be problems. Easy enough to fix on a canister without a built-in purge valve (just replace the valve) but harder on a can with an integral valve.
PostPosted: Fri Apr 10, 2015 9:22 am
Dan,
To check the purge valve, one would just pull vacuum on it correct?
If it holds vacuum it should be good?
Dave
86 Miser 170,000+
2 1/4" exhaust
Holley 1920 #55
HEI MSD BLaster 2
17.8 mpg
PostPosted: Fri Apr 10, 2015 10:52 am
It has to hold vacuum on its activation port, open when vacuum is applied, and close when vacuum is released.
PostPosted: Fri Apr 10, 2015 2:04 pm
Went to my local NAPA store and was informed that part number references to:
Subaru XT 85-91
Subaru 1800 85-87
Subaru XT 2.7 89-91
Subaru Justy 1.2 87-92
Users browsing this forum: Bing [Bot], Google [Bot], morsim and 12 guests
