It is currently Thu Oct 08, 2026 9:33 pm
 Post subject: Hei conversion
PostPosted: Sat May 09, 2015 4:14 pm
I'm drawing blanks here. I'm almost finished with a project truck I started almost a year ago. Going to do the HEI conversion, but my question is...How does this effect alternator wiring? Its an 82 slant in a 70 Swepty with a 2 blade one post alternator with a Painless harness. Red wire to the post, white to silver blade, brass colored blade to ground? I haven't seen any mention of what to do with the alternator wiring after putting in an HEI system. Might be I'm just tired and missing something.
AlaskanMopar
1970 D200
4wheel disc Conversion
Skyjacker 2" Lift
PostPosted: Sat May 09, 2015 4:36 pm
Why do you think something needs to be done with the alt wiring?
 Post subject: Re: Hei conversion
PostPosted: Sat May 09, 2015 4:47 pm
It doesn't. The alternator doesn't know or care what kind of ignition system you have.
PostPosted: Sat May 09, 2015 5:18 pm
I mention this because according to the 70 wiring diagram the light green wire gores to the alternator regulator(term used on the diagram(voltage regulator
/)), black off the alt regulator is pigtail to a red wire going back to the ballast resister on one side then on the other side pig tailed to pink and red, red going to the coil. If I take out the ballast putting an HEI module in and coil...
Also am I getting mixed up in terms with voltage regulator, altenator regulator and ignition module?
AlaskanMopar
1970 D200
Skyjacker 2" Lift
PostPosted: Sat May 09, 2015 7:20 pm
I don't see the wire colors you are reffering to, except for the green wire.
Look at this diagram.
http://www.mymopar.com/downloads/1970/7 ... usterA.JPG
I don't have a truck diagram available, but I am pretty sure the charging and ign circuits are the same, as are the colors.
PostPosted: Sat May 09, 2015 7:36 pm
OK, I found a 70 truck wiring diagram, and I see where the problem lies.
1970 truck used a single blade one post alternator, and a mechanical regulator. The two blade alternator can be used by grounding one of the blades.
Leave the charging system wiring alone (keep it as the factory did it). remove the ballast resistor, and connect all three wires together. Use the red wire at the coil as the B+ to the HEI.
PostPosted: Sat May 09, 2015 7:50 pm
Disregard everything I said. I think I am wrong. Need to study the truck diagram a little more.
The problem I am having is which voltage regulator is used. I thought 1970 still used the mechanical voltage regulator, but the parts list shows the electronic regulator.
PostPosted: Sun May 10, 2015 11:07 am
You're making this a lot more complicated than it is. You don't have to, and shouldn't, change any of the charging system wiring. Leave it alone. Don't touch the voltage regulator (which nobody but occasionally the people writing the service manual ever calls an "alternator regulator"). There is no ignition module to think about on your truck unless someone in the past converted it from the original points-type ignition to a Chrysler or other-brand electronic ignition.
Remove the ballast resistor and discard it. Connect to each other the two connections that used to connect to either side of the ballast resistor. Proceed as described at HEI upgrade article.
PostPosted: Sun May 10, 2015 1:04 pm
Yes, agreed. My problem with the original description was the wiring colors. I see the truck diagram uses a different color on the voltage regulator wires then the cars.
Just discard the ballast resistor, and connect any/all wires together. The wire the originally went to the coil positive (+), is used to either power the HEI directly, or trigger a relay that powers the HEI.
Personally, I don't see the need for a relay, though some will disagree with that.
PostPosted: Fri May 22, 2015 3:35 pm
Nor did I, until my truck wouldn't turn off. :roll:
PostPosted: Mon May 25, 2015 4:53 pm
I agree with Charlie, I've done a HEI upgrade to four of my vehicles, never used a relay on any of them. I still own and drive two of them. I have never used heat sink either. I bolt them to the top of the inner fender, run two wires to the coil, two more to the distributor and fire it up.
