It is currently Fri Nov 20, 2026 3:54 pm
 Post subject: Valve cover
PostPosted: Thu May 14, 2015 1:42 pm
I am trying to find a new Valve Cover for my 82 hydraulic head. Unless my reading has been wrong and I am off my rocker(pun) to many people still get it wrong The Hydraulic head valve cover does not fit a mechanical head valve cover and vice versa. Does anyone happen to know where I can get a new valve cover or a good used one that can clean up and be repainted well for my hydraulic head 82 slant?
AlaskanMopar
1970 D200
4wheel disc Conversion
Skyjacker 2" Lift
PostPosted: Thu May 28, 2015 10:18 pm
Car Model: 1965 Barracuda super six
I have the same problem. As far as I know there are no reproductions. With a little bit of luck you can probably find one at a junk yard. Technically every slant 6 car after 1981 should have that valve cover?!
PostPosted: Fri May 29, 2015 4:43 am
Car Model: '23 T-bucket
I think I'd be more inclined to search in vans and pickups. If memory is correct, the slant was dropped out of cars in '84, but used in the light trucks to '87.
Good luck.....Roger
PostPosted: Fri May 29, 2015 8:27 am
Good luck.....Roger
Correct.
