It is currently Wed May 06, 2026 6:35 am
Post new topic  Reply to topic  [ 1339 posts ]  Go to page Previous 163 64 65 66 6790 Next
PostPosted: Sun Jun 07, 2015 12:47 pm
How did the car run yesterday? 11' seconds ?? :lol: Glad you got it going for Wilkesboro.
Rick
PostPosted: Sun Jun 07, 2015 2:25 pm
Rick
It was Solid.
No Eleven Seconds.
I tried a Different Converter that I had not Run yet and it slowed the 60'.
The air was average to bad also - not horrible but could have been better.
4 runs - It was a regular race day and I won round 1
12.28
12.12
12.06
12.08
PostPosted: Sun Jun 07, 2015 5:25 pm
Those are still really good numbers Greg! Especially if you got the ignition issues worked out! 11's around the corner. :lol: :lol:
PostPosted: Sun Jun 07, 2015 6:34 pm
:D
PostPosted: Mon Jun 08, 2015 6:28 am
Excellent!
PostPosted: Mon Jun 08, 2015 9:57 am
Yes now that it's sorted, I can play with Ign timing, Carb Spacers, and rear suspension!
PostPosted: Mon Oct 12, 2015 6:56 pm
It's Been quite A while since I have Posted any updates.
I surely Wish I would have gone more rounds at the Mason Dixon 2015 Fall Slant 6 Race, But It was not my day to be consistent;
I did Make 8 Passes, 7 Of which were solidly in the 11.99 or lower Range.
The First pass was a throw away at 12.10
MPH Was up to 111.XX and I did Squeak out a 112 MPH Pass Once!
So I Lowered my personal Best ET to 11.896 @ 112.05
If I can get the car to Run Consistent 11.80-90 Next year, Then in "good" air I can maybe pick up .4 and Be within Guzzi and Pederson Range for A or B Gas..... One can Dream!
Here is a rundown:
Pass 1: 12.10 @ 110.19
Pass 2: 11.93 @ 111.78
Pass 3: 11.89 @ 112.05*Personal Best to Date
Pass 4: 11.94 @ 111.19
Pass 5: 11.95 @ 111.39
Pass 6: 11.97 @ 111.23
Pass 7: 11.98 @ 111.25
Pass 8 :11.93@111.54
VIDEO LINK:
https://www.youtube.com/watch?v=siW_JeviPTA
PostPosted: Mon Oct 12, 2015 7:40 pm
RUSTAAAAHHHHRRRR!
PostPosted: Mon Oct 12, 2015 11:15 pm
Congratulations Greg!
PostPosted: Tue Oct 13, 2015 4:01 am
11's!!! That's great!!
Kev
PostPosted: Wed Oct 14, 2015 6:38 pm
11`s on motor is great!! I couldn`t do it. :cry:
PostPosted: Fri Oct 16, 2015 9:07 am
Congrats,,,,,,hopeing engine freshen up and new headers I can bee in the 11.20s.
PostPosted: Fri Oct 16, 2015 4:35 pm
Thanks mark.
Good luck in your search for 11.20. I am sure it will be harder than 11.43.
PostPosted: Tue Dec 01, 2015 9:39 am
Hello Folks,
It's that Time of year when the 904 Transmission Is going to be rebuilt and upgraded with a Full Roller Kit with all Torringtion Bearings and Roller Bearings - No More Camshaft style bearings and Shims. Also, the Drums and a few other Components are being upgraded to A&A Transmission's Billet Aluminum Componets with a lower first Gear Ratio:
Pictorial update:
Transmission workbench:
Old:
New A&A Piece:
The new piece weighs only 3.810#
Old Front Drum - 6.532#
New A&A Aluminum Front Drum - 3.030#
Old Sunshell with 2.45 Low gear & New Sunshell with Holes and Low 1st Gear Comparison:
Old Sunshell was 3.022#
Sunshell with Holes was 3.034#
THe larger Low gear added weight.
Front Planetary Gear Comparison:
No Trick Light stuff here - Just Torringtions every where :-)
Note size change to go from 2.45 Low Gear to Lower Ratio.
Rear Planetary Gear Comparison:
Rear Drum Comparison:
Steel Rear Drum - 3.336#
A&A Aluminum Rear Drum - 1.362# - with Roller bearings!
I will have a mass comparison prepared soon.
All the New parts save about 6# of rotating mass!
Hopefully all this work and Ca$h will drive Ruster Deeper into the 11's
PostPosted: Tue Dec 01, 2015 12:05 pm
looks like your also going from a 3clutch to a 5clutch drum. are you going with the up dated coil spring front piston like a 727?
