It is currently Tue Nov 17, 2026 11:53 pm
PostPosted: Mon Jun 22, 2015 12:04 pm
Well, I have a leaking axle seal in my '65 Dart, and I've tried a puller, I've pulled the cover and tried prying between the cross shaft and the axle itself, and the axle just won't budge. I pulled the four nuts from the retainer...any ideas???
1965 Dodge Dart 170 Wagon
1965 Ford Mustang
1965 Buick Skylark Hardtop
1965 Chevy Corvair Monza Convert.
1953 Buick Special Riviera
PostPosted: Mon Jun 22, 2015 3:42 pm
If you have an old wheel put it on the axle and whack the back lip with a hammer. The bearing is just stuck in the goo in the end of the axle tube.
PostPosted: Mon Jun 22, 2015 4:35 pm
Car Model: '23 T-bucket
Warm up the end of the axle tube with a propane torch. That should soften up the goo that 'Zilla mentioned, as well as expand the end slightly.
It would be more effective if you could put a bit of pulling tension on the axle as you do this.
Roger
PostPosted: Mon Jun 22, 2015 4:44 pm
Wow...it must really be gooey! I've never seen anything like this!
I don't have an extra wheel lying around in this bolt pattern, unfortunately! Time to buy more A-Bodies so I have more parts. :) I'll start out tomorrow trying the heat.
1965 Ford Mustang
PostPosted: Mon Jun 22, 2015 4:58 pm
Bolt a chain to one or more of the studs and use a Sledge hammer as a slide hammer to give it some persuasion . Works every time !!
PostPosted: Thu Jun 25, 2015 10:41 am
Wow...it must really be gooey! I've never seen anything like this! ...
When they are stuck like that... it is usually rust "goo" between the bearing & housing socket. :roll: :lol:
Spray some "Blaster" in there and let it soak-in.
Me... I just beat the crap out of the backing plate, from behind, until the axle pops loose... then replace the backing plate. ( let me know if you need one, I have extras)
PostPosted: Thu Jun 25, 2015 1:03 pm
Whereabouts are you located? Are you still using the original small-bolt-pattern 13" wheels? So many people have upgraded from those that there may be a forum user near you with some extras laying around.
Escape Velocity Racing
PostPosted: Thu Jun 25, 2015 9:53 pm
Car Model: 1964 Dart 270
I used a slide hammer on mine, pulled four axles out of two 7.25 rear ends. The slide hammer seems to work the best.
http://m.napaonline.com/Tablet/parts/Pa ... 0361145781
1964 Dodge Dart 270 four door. Three speed automatic 225 Slant with a Carter BBS carb.Image
PostPosted: Fri Jun 26, 2015 7:40 am
I'm in Michigan...still using SBP wheels...
After trying everything up to pounding the backing plate, I took it over to my local shop to let them give it a shot. At that point, pulling the u-bolts and unbolting the driveshaft was worth it.
I told them to work on it for an hour, so we'll see what happens. I hate giving up like that, but sometimes you just know when you're going to start breaking stuff needlessly. :)
If THEY can't get it, I'll take you up on your used backing plate, Doc. :)
1965 Ford Mustang
PostPosted: Mon Jul 13, 2015 5:21 am
An update for those interested: The shop got it, but it was a two man job; one guy used heat while the other guy used the slide hammer. They were really, really stuck in there. I got it all back together again now, however, with no leaks.
Thanks for the ideas!
1965 Ford Mustang
Users browsing this forum: Amazon [Bot] and 2 guests
