It is currently Tue Jun 23, 2026 8:36 am
Post new topic  Reply to topic  [ 21 posts ]  Go to page Previous 1 2
PostPosted: Wed Jun 17, 2015 12:09 pm
Well aware of all that. I used real thermal grease. That 8 amp draw stuff - at real high rpm on a v8, not idling on a 6 when I was observing the too hot to touch symptom. Current will be proportional to rpm. In fact I recall measuring amp draw at less than 1a in gear idling.
Does your heatsink get too hot to touch after a drive, perhaps on a hot day?
PostPosted: Tue Jun 23, 2015 3:29 pm
Sure, pics welcome.
As promised.. Pictures.
I have not measured temperature of the heatsink yet.
PostPosted: Tue Jun 23, 2015 3:42 pm
Nice. If yours is happy like that mine should be fine. Without comparing the numbers on it, that appears to be the same exact module as my napa tp45, including the odd metal tab that comes out one of the diagonal sides.
PostPosted: Tue Jun 23, 2015 5:37 pm
It was a standard.. dont remember the exact part#... but most likely the same
PostPosted: Tue Jun 23, 2015 6:27 pm
Greg, I'm not sure why you're worrying about HEI heat sinks. You've got much bigger problems underhood. Your engine has two cylinders too many, and half the cylinders are on the wrong side! :shock:
PostPosted: Tue Jun 23, 2015 6:36 pm
oops. Thanks fir for pointing that out. .. I never even noticed.
