It is currently Fri Jul 17, 2026 10:05 pm
PostPosted: Tue Jul 14, 2015 7:03 pm
I am having trouble finding the low oil pressure cut off switch that Mopar Performance used to sell. It just had a one wire connector on it. Thanks for any help.
Rick
PostPosted: Sat Jul 18, 2015 9:49 am
bump
PostPosted: Sat Jul 18, 2015 11:21 am
What are you trying to do Rick?
PostPosted: Sat Jul 18, 2015 11:36 am
I want to kill the ignition system if I loose oil pressure. I have one on the race car and I want to put one on the "race truck". I would prefer them to be the same.
I got the one on the car from Mopar performance years ago and was hoping to get the same one. It has a single wire and shuts the engine off at about 10 or 12#. It has saved my bacon once already! :lol:
Rick
PostPosted: Sat Jul 18, 2015 3:23 pm
Wouldn't a regular oil sender for a light do the same thing?
PostPosted: Sat Jul 18, 2015 5:25 pm
I am guessing yes? So which one is going to be at about 10# ? Probably most any of them would work.
Rick
PostPosted: Sat Jul 18, 2015 6:05 pm
AFAIK, the factory ones are 7-10#.
PostPosted: Sat Aug 01, 2015 5:59 am
Ok, I found the one I wanted from Central High Performance in NC. It looks like NOS and it was from Mopar Performance. Part # is 412033 just in case anyone else wants it. It cuts the ignition at 15# so that gives you a little bit more of a safety cushion over a 7-10# factory one although I am sure they would work too. Cost was $20 plus shipping.
Rick
