It is currently Tue Jun 09, 2026 12:36 am
 Post subject: the bad gas saga
PostPosted: Mon Aug 10, 2015 7:18 pm
been driving the 83 D150 a lot this summer, very predictable performance,
ran the road up to the Chicago area, bought gas at the
Bucky's Mobile 542
1000 Wood Dale Road
Wood Dale Il
on 8/05/15,
13.5 gallons in a 26 gallon tank..
and started home to Indy, ran fine on 65 S
65 to 70 no issues, I do have a LED knock sensor and it lite more than normal, issue was as soon as I got off the highway, the 83 D150 would not idle, it would re start as normal on a hit of the key, let off the throttle and it would die, ran the idle adjustment up, no change
got home-city driving with a lot of agrivation, figured I burnt a valve, checked compression
175
175
178
180
180
180
after 15K miles a testament to the work at Ed's Machine Shop in Morresville IN, recommended shop...
back to the issue..
I could screw with the carb and get it to idle,,sort of,, with everything hugely out of balance, like it did when it had a huge vacuum leak, pulled the intake and dual Dutra's,, everything was sealed fine, just a lot of fun for no good reason, seriously,, it is a PITA to pull and re set a slant six manifold system, on a D150, for no good reason..
:shock:
The 83 D150 is running a 90 D150 fuel system, in tank pump, ,,, with that I have a Fram Filter.
went to change that, here is a photo
https://www.flickr.com/photos/13718356@ ... datetaken/
the fuel that was in the fuel filter housing, does not even smell like gasoline, I got a tank full of water-gas ,,
in that photo
new filter on left
existing filter in middle
"water" bottle has what was drained from the fuel filter housing, figure I have another 13 gallons of that in the fuel tank.
breaking to the story, I will be calling that dealer and Mobile tomorrow,
got some water diluted gas to resolve.
 Post subject: Re: the bad gas saga
PostPosted: Mon Aug 10, 2015 7:33 pm
This sounds like a big fire just waiting to happen. Also sounds like you've been lucky…so far.
PostPosted: Mon Aug 10, 2015 8:11 pm
SSD, you missed the point of this post, regardless, the 83 D150 has an engineered fuel system with a by pass regulator cutting the in tank pump pressure down to a dead head regulator to feed the carb, meanwhile, back to the post on bad fuel...
PostPosted: Mon Aug 10, 2015 8:54 pm
Good…how 'bout an oil pressure interlock and inertial cutout?
No, I just didn't confine my remarks to what you asked, is all. It probably won't be the last time.
PostPosted: Tue Aug 11, 2015 7:19 am
no inertia lock out, I do have the fuel pump power relay activated off the oil pressure switch...
the tank vent has the OE roll over valve installed and functioning..
PostPosted: Tue Aug 11, 2015 8:55 am
It's amazing that it ran that well all the way home John.
PostPosted: Tue Aug 11, 2015 4:56 pm
changed out the inline fuel filter, figured I should go ahead an change the filter on the in tank pump,
when I set up the fuel system, I also cut in a removable panel in the floor of the bed, in case I needed to service the in tank pump,
https://www.flickr.com/photos/13718356@ ... 7128013281
worked out real nice,,
along with the knock sensor flashing occasionally, the engine temp gauge was indicating a lower than normal coolant temp,, not a lot, but enough to notice and think,, 'that is not where it normally runs..'
maybe it was motoring along on water power.
PostPosted: Wed Aug 12, 2015 5:26 am
More like hybrid gas/steam... Now if you could hookup four of those Tucker torque converters for each wheel, and a pop-out windshield.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 4 guests
